StephenA Posted September 23, 2021 Report Share Posted September 23, 2021 Just wondering why no-one ever made a ribbed belt kit for the BMC 1.5 I know you'd not want to increase the tension over what is currently there so it doesn't take out any of the bearings but....... Link to comment Share on other sites More sharing options...
Tracy D'arth Posted September 23, 2021 Report Share Posted September 23, 2021 4 minutes ago, StephenA said: Just wondering why no-one ever made a ribbed belt kit for the BMC 1.5 I know you'd not want to increase the tension over what is currently there so it doesn't take out any of the bearings but....... I started to turn one for the crankshaft in BMC engines. Then realised that it is a non starter on 2 counts. 1 The crank pulley has a rubber bonded torsional damper inside without which the crank can fracture. 2 The pulley relies on half the woodruff key which also has to drive the sprocket, it is to weak to take much extra power transfer. Link to comment Share on other sites More sharing options...
StephenA Posted September 23, 2021 Author Report Share Posted September 23, 2021 7 hours ago, Tracy D'arth said: I started to turn one for the crankshaft in BMC engines. Then realised that it is a non starter on 2 counts. 1 The crank pulley has a rubber bonded torsional damper inside without which the crank can fracture. 2 The pulley relies on half the woodruff key which also has to drive the sprocket, it is to weak to take much extra power transfer. So basically it would be an engine killer even if you kept the alternator load at the same level. Link to comment Share on other sites More sharing options...
Tracy D'arth Posted September 23, 2021 Report Share Posted September 23, 2021 2 minutes ago, StephenA said: So basically it would be an engine killer even if you kept the alternator load at the same level. Without the damper, yes. Link to comment Share on other sites More sharing options...
