Calorifier fitting size
I have an Albion horizontal twin marine calorifier 800 X 300, 3 bar shell, 3.5 bar coil, works order IP 1803, dated 04/02/08. Does anyone happen to know the thread size on the cold water input? I believe it might 1/2" BSP but cannot confirm this without draining it down and removing it. The fitting has developed a slight weep and needs replacing. I would rather buy the part before draining the system if at all possible. Thanks.
If you have union nuts  :-   1/2" BSP =  ! inch across flats,  3/4" BSP = 1.2 inch across flats.
 Share
