Old Sterling Inverter charger power saving function problem
Hi all, I have the pictured Sterling inverter charger, probably about 15 years old as I think it was fitted to the boat from new. It has a power saving function which keeps the inverter in a standby mode until a demand is detected. The problem is it now seems to be having a problem detecting when there is demand, particularly from small draw devices. I believe that it is possible to deselect the power saving function? Just wondering if anyone has or has had this type and knows how to do it. I am currently working around the problem by switching on a 230v lamp which brings the inverter out of standby mode so that I can then use the device I actually want. Thanks in advance for any advice.
The power saving function works quite well, but as you have observed, it does need a reasonable current draw (around 1+? amps) to trigger. Unfortunately there is no way to adjust this threshold.
BTW, I do hope the box has some good ventilation as it does need ventilation to disipate the heat when working hard.
Invertek DAI-3000C-12xx.pdf
Edited by Pennine
  • 2 weeks later...
Hi all, just in case anyone else has this problem with this Sterling inverter charger and finds this post on a search, I now have the pictured instruction sheet which shows how to program the settings including switching off the power save function.
 Share
