LUCE1923 Posted April 28, 2021 Report Share Posted April 28, 2021 Hi all, last Saturday my gearbox output shaft broke, its a yanmar engine with a kanzaki gear box anyone got any advice on where to find a reasonably priced replacement???? Link to comment Share on other sites More sharing options...
Tony Brooks Posted April 29, 2021 Report Share Posted April 29, 2021 I am afraid not from inland sources but if this is a proper marine Yanmar then there are agents around the coast. However, I have never seen a failed output shaft on any gearbox. This does not mean it has not happened but its rarer so unless you can see the two sides of the broken shaft I suspect misdiagnosis. That is unless the engine alignment was way out but you would then have been suffering from horrible vibrations. If its something a man in a shed put together then that gearbox might be from a machine that does not create end thrust on the shaft so using it on a boat is likely to end in failure. Link to comment Share on other sites More sharing options...
Tony Brooks Posted April 29, 2021 Report Share Posted April 29, 2021 Try: https://www.frenchmarine.com/Yanmar-Gearboxes-397 But it looks like it will be very expensive. Or https://www.boatpartsandspares.co.uk/yanmar-gearbox-283-c.asp Link to comment Share on other sites More sharing options...
