House ring main failed - help!
9 minutes ago, The Happy Nomad said:
Suggesting that its water resistant but not resistant to being continually submerged?
True, PVC is not totally non permeable to water.
See this report,     https://apps.dtic.mil/dtic/tr/fulltext/u2/656243.pdf
Its a known phenomenon of many plastics.
Thanks for confirming. In that case I reckon there is an excellent chance Richard has solved his problem long term
It is very bad that cable under a floor in a wet subfloor space are not clipped up away from the wet and puddles in this space are really bad.
Is there a leak from a drain or a run off getting into the space or is it a defective oversite concrete allowing the water table to rise into the space?
11 minutes ago, ditchcrawler said:
Not something I have ever experienced, I would suspect a mouse or rat
OK, if in doubt blame poor Mickey or Roland.  Innocent rodents, they don't understand electricity.  The worst rodent damage I ever saw was by squirrels.  ( no, mot cast iron ones )
  Easier than blaming the cowboy that draped cables on the wet floor.
Now they are the worst without doubt, not sure how they get away with so much damage without electrocuting themselves. The old VIR was also favoured by rats/mice but in dry areas again you could get quite a bit of damage before the copped it
Agreed. It was done long before we bought the house, and we have had no reason to look under the floor until now. As I said, it’s a bit of a dogs breakfast, so I’m sure we’ll be having it tidied up later in the year.
My guess is it’s water table related. Last week we had lots of rain, and areas nearby were actually flooded. Also the fact that it has soaked away suggests this. Having said that, it could be getting in from outside and above.
I had a client who had watched the squirrels run up into his roof for weeks, thought they were cute!
Until his heating stopped working. The roof space was a disaster area. Insulation balled up into nests, (drays) cables with insulation gnawed off, roof members reduced to matchwood but the best was the cold water cisterns  gnawed down to the water level. It cost thousands to put right.
  • Horror 1
I had that at a previous house squirrels can do serious damage quickly!
We had a pet rabbit who was an absolute dab hand (paw?) at nibbling both live and neutral insulation but not electrocuting himself. He'd sit and watch until we moved the standard lamp (or whatever) and there was a big blue flash and a bang. He was confined to his cage after gnawing through a (very expensive) HDMI cable!
On 21/01/2021 at 02:32, Richard10002 said:
Watching TV this evening when everything went off, or so it seemed. However, when I got to the main fuse box, if I turned off the “downstairs ring main”, the “main switch” that was automatically turning everything off, stayed on.
So the problem is somewhere in the downstairs ring main sockets. I turned all the sockets I could find/think of off at their switches, thinking this would remove the problem, then I could turn them on one by one, and the faulty one would cause the switch to throw.
Not to be - having turned all the sockets off at the socket switch, turning the downstairs ring main switch on caused the main switch to throw. So I either haven’t found all of the sockets on the ring, or the problem is with the wiring to the sockets, or something else that I can’t think of.
I don’t want to waste the time waiting for an electrician if this is something I can diagnose myself, so I wonder if anyone, (an electrician?), has any pointers. I’ve got a few tools and meters, so should be able to do what an electrician would do.... up to a point.
Hope that makes sense,
Richard
BTW: it seems that we have a Kitchen and Garage ring main, so there are some ground floor sockets that work, and I have managed to get critical stuff working with a few extension leads, (TV and Fridge Freezer mainly).
You have one heck of a big boat :)
Interesting, we are near Tring and moor at Cowroast, thanks to Lord Rothchild and his 'Zoo' at Tring, Glis Glis are the problem for us. They chew anything and what they don't chew they crap over. The current Lord R. denies all liabilty, they have spread as far as Amersham.
do they spread covid?
At least you can eat them.  Handy for when Amazon fail to deliver your grocery.
A woman near us breeds Guinea Pigs, they sell for £45 each!
That’s over a hundred quid for a meal two including wine etc!!!!  Makes Waitrose look cheap.
Though you would have to make do with quails eggs and caviar as they don’t do guinea pig.
Edited by Chewbacka
Grey squirrels are an absolute pest, reds on the other hand.
I would be happy to see a concerted effort to reduce greys numbers, probably is even greys have the cute factor
Looks like it Tony :)
My letting agents electrician came this morning.
He did a proper job of clipping the suspect cable to a joist then opened up the Consumer unit, pulled out the downstairs ring wires from the MCB, (or whatever it is), did a couple of tests for high Ohms, (80 Meg Ohms and 90 Meg Ohms), and a continuity test for low Ohms, (0.35 Ohms), so all good fir the time being.
The tests were extremely simple, all done whilst sitting at the Consumer Unit, although I suppose if he had had to chase a problem, it would have been a bit more involved.
I plan to get him back when we’ve all been vaccinated and the Covid situation has settled down a bit. The suspect cable could do with replacing, even though it tested fine, and there is a bit of underfloor tidying up that could do with doing.
Thanks again to everyone for the help.
19 minutes ago, Tracy D'arth said:
Glad that it was not too complicated. 80 megs is surprising me considering that the cable was the problem, I would have thought it would be much lower.
It makes me wonder what voltage he used but pleased it all seems OK.
If its a damaged cable, moving it could have cleared it completely and the conductors are just sitting there side by side
He said he was going to feed 500v into it, and made sure there was nothing plugged into any of the sockets.
Nice looking machine with a touch screen, although I didn't get close enough to see any detail.
That is what I would have done, not that I am mains experienced.
