Murflynn Posted October 27, 2020 Report Share Posted October 27, 2020 found this while surfing you-tube https://www.saltdays.co.uk/products/ferrule-crimping-wire-pliers-tool?variant=32724765114452 looks interesting, has anyone tried it? Link to comment Share on other sites More sharing options...
GUMPY Posted October 27, 2020 Report Share Posted October 27, 2020 Yes we used to have them at work. Leaves a castellated ferrule along its length. Not that good IMO. Prefer this type, gives a better crimp. https://www.cablecraft.co.uk/crt-0-14-2-5-cord-end-tool-0-14-2-5mm?gclid=Cj0KCQjwit_8BRCoARIsAIx3Rj5HX2v9mlbJOZIbCQdxx3K94qsCe6LPkR6cQXhZg32VopTzZhdIoY4aAraEEALw_wcB Cheaper versions are available Link to comment Share on other sites More sharing options...
dmr Posted October 27, 2020 Report Share Posted October 27, 2020 I have one of these, it works ok. Its fine for bigger cables (more than 2.5mm) but maybe not for thinner ones, it does give a castlelated crimp and after putting this into a chocbloc connector they bend and weaken. or maybe this is a weakness of all ferules on thinner cables? ................Dave Link to comment Share on other sites More sharing options...
Batavia Posted October 27, 2020 Report Share Posted October 27, 2020 The type recommended by Julian is infinitely better for small bootlace ferrules, as it doesn't damage the ferrule (much). For best results, it is worth adjusting the tool to suit the particular ferrule being used, as their wall thicknesses can vary noticably. Chris G Link to comment Share on other sites More sharing options...
Slim Posted October 27, 2020 Report Share Posted October 27, 2020 1 hour ago, Murflynn said: found this while surfing you-tube https://www.saltdays.co.uk/products/ferrule-crimping-wire-pliers-tool?variant=32724765114452 looks interesting, has anyone tried it? 1 hour ago, Murflynn said: found this while surfing you-tube https://www.saltdays.co.uk/products/ferrule-crimping-wire-pliers-tool?variant=32724765114452 looks interesting, has anyone tried it? Looking at the photographs (couldn't enlarge them) they don't seem capable of being deployed over a cable such as when using an in line connector . May be wrong, often am Link to comment Share on other sites More sharing options...
dmr Posted October 27, 2020 Report Share Posted October 27, 2020 25 minutes ago, Slim said: Looking at the photographs (couldn't enlarge them) they don't seem capable of being deployed over a cable such as when using an in line connector . May be wrong, often am They are for ferules only, not a general purpose crimping tool. ...................Dave 1 Link to comment Share on other sites More sharing options...
jonathanA Posted October 27, 2020 Report Share Posted October 27, 2020 No need for a tool for most of the insulated types, the action of the terminal/ connector crimps the ferrule on to the wire. Many are designed to work that way. Personally I prefer to use a crimping tool like the one linked to by Loddon. Think I paid £15 for mine including 500 cord ends of varying sizes. Link to comment Share on other sites More sharing options...
Cheshire cat Posted October 27, 2020 Report Share Posted October 27, 2020 Do you need something beefier to put the battery connector on the end of a 6mm solar cable? I shall be attempting this shortly. Link to comment Share on other sites More sharing options...
George and Dragon Posted October 27, 2020 Report Share Posted October 27, 2020 4 hours ago, Cheshire cat said: Do you need something beefier to put the battery connector on the end of a 6mm solar cable? I shall be attempting this shortly. Something like this https://www.autoelectricsupplies.co.uk/product/470/category/87 for insulated ring terminals up to 6mm^2 Link to comment Share on other sites More sharing options...
