Skip to content
Are LED Tunnel Lights Really Necessary
Featured Replies
#201
7 minutes ago, Kipper 2 said:
At the end of the day, with an LED tunnel lamp if you point it up to illuminate the roof of the tunnel you can see exactly where you need to steer plus anyone approaching will see the light and not be dazzled.
Unfortunately that's not the case with a lot of the LED lights that some boaters use as "tunnel lights", they have very poor beam control so there's a lot of light outside it, and often the actual LEDs are directly visible when looking at the light as small extremely bright point sources. Also they tend to be smaller diameter/area than traditional headlights, so the light intensity when you look at them is higher.
All this means they can be a lot worse for dazzling oncoming boaters, especially the cheapo ones which chuck light (lots of it!) everywhere -- I've been subjected to boats coming the other way in tunnels where the only way to see anything at all was to hold up your hand/arm directly between your eyes and the oncoming retina-burner... 😞
You can get LED lights with decent beam control which are much less dazzling, but they're also a lot more expensive than the cheap eBay/Amazon ones. Guess which most boaters choose... 😉
Edited by IanD
#202
Which is pretty much what I do with my non-LED tunnel lamp. I have never really gone with this idea of having any bright, forward facing light since I'm already standing 60 feet back from the front of the boat so, if there is anything untoward in the water ahead of me, I ain't going to see it anyway. If the light were bright enough to actually see anything in the water far enough ahead for me to do anything about it, it would need to be a pretty intense light. It also has to been borne in mind that someone coming the other way is going to be doubly dazzled, from the lamp itself AND from the reflection off the water.
All that I now do is illuminate the tunnel roof which gives and arc of light and then position the boat in the middle of that arc (unless, obviously, there is something coming the other way;)).
#203
In a fit of battery-saving energy efficiency I replaced the filament bulb in my old-school chrome car headlamp with a warm white LED lamp; the light emitted is indistinguishable. I then realised that I only ever use it when the engine's running, which makes the whole exercise a bit pointless, but if my alternator ever fails and I need to go through a tunnel to get to the alternator shop I'll have the last laugh...
#204
My headlight (the boat came with it fitted) is a relatively big (9" diameter?) traditional-type halogen headlight, with reeded (patterned) glass to diffuse the light and spread it out -- I guess it's a retro motorbike headlight. It doesn't give a bright spot-type beam pattern, it spreads out over quite a wide area but is not very bright anywhere.
Edited by IanD
#205
Mine is not dissimilar to that but the bracket enables it to be directed upwards since I only need to see the tunnel roof to position the boat (it also came with the boat).
Is that a horn or a bell?:huh: If a horn might be more effective facing forwards;)
Edited by Wanderer Vagabond
#206
Mine also now points more upwards than in the picture, which was taken when the boat was being built -- the bracket is adjustable.
It's a horn; facing down under the bracket keeps the rain out, and the sound is fine... 🙂
#207
I replaced my nav light bulbs with LEDs, not for efficiency, but while I had the fittings off for painting.  I'm hoping the 20,000 hour MTBF will mean I never need to replace and reseal them!
They aren't bright enough to be appropriate for my boat, but then the fittings themselves are too small anyway as is quite common on narrow boats.
They may not be up to the correct specification but they do give a cheerful christmassy effect in tunnels, and they are visible at long enough canal distances to be useful in low light conditions.
#208
I’ve yet to try it but I’m at the point of needing to wear sunglasses or  anti glare ones garages sell in tunnels when some boats approach. Has anyone tried that? It’s getting rare to see boats with the appropriate style lamp that @IanD has, angled upwards.
It’s strange this isn’t a BSS fail as it’s a potential danger to other boaters in tunnels. I find it quite hard to see my position properly with an interrogation light approaching. Thankfully I’m not in a GRP boat.
Headlights are an important part of cars MOTs after all, appreciate the speed difference.
Most things BSS  adjust seem vital changes such as will your battery stay in place when your boats upside down
#209
1 hour ago, Stroudwater1 said:
.........wear sunglasses or anti glare ones garages sell in tunnels..........
I've not seen many (if any) garages in canal tunnels.
#210
Thinking about glare, whether on / from boats in tunnels or cars/ joggers et al on roads it seems to me that few , if any  actually consider the issues of  'being seen' and being able to see as seperate conditions -  Daylight running lights - bright enough to be visible in sunshine  become blinding at night if not dimmed by some means, likewise those blue Emergency service lights can blind more than reveal at night - several times  on passing incidents at night it has proven hard to see the road, debris, or even the personnel due to the steep contrast of bright flashes and pitch black backgrounds.
" soft" lights that illuminate a tunnel roof for navigation need only be a few lumens but of a very wide pattern seeing some distance ahead without 'blinding others surely requires something like old white foglights, possibly hooded - a la WW2 aimed downwards to minimise forward glare. but  provide general illumination a couple of hundred feet ahead or dipping style lights that can be switched for approaching boats - true  they would cost something extra - though little in the grand scale of things  - so IMO   more a question of peoples consideration of others and ability to meet changing conditions rather than any number of regulations
-  Oh dear I seem to be requesting intelligent and considerate humans to multiply, 🙄
#211
Not RCD/RCR compliant then ? 👿😁🤣
#212
It's built out of imperial plate, so I'm not concerned about these newfangled rules.
Admittedly a baseplate thicker than a quarter of an inch would have been nice, but that wasn't really a thing in the early 1980s.
We just keep quiet about the specifications in the COLREGS ... ;)
#213
I suggested exactly the kind of foglight you describe -- wide flat-topped beam but mounted upside-down tonight up the tunnel roof -- to Ricky, but they're very difficult to find nowadays since there's almost no market for add-on car foglights any more.
I would have also installed another one the normal way up to light up the canal/bank ahead when cruising at night, separately switched because in tunnels this would bounce off the water into the eyes of oncoming boaters... 😉
#214
I remember someone using an inverted headlight, Dip beam up on the roof, head beam straight ahead. mounted in the front bulkhead just below the roof
#215
That would work too -- in fact in modern ones the dipped beam "kicks up" to the left, which would be a kick down at the right when inverted -- perfect for tunnel wall and not blinding oncoming boats... 🙂
#216
It was in the days of headlights in the front of the wing of a car with a sort of dish behind it
#217
I would have thought that would be called many things including  a backshell or possibly a bowl or a bucket
#218
But there are inland waterways where COLREGS compliant nav-lights are required, so really, if fitting them, you should use the correct ones.
Edited by Alan de Enfield
#219
I am glad you knew exactly what I meant
#220
Old cars used to have them . Before the days of wheel arch liners they became covered in road dirt and could rust through.
#221
That type of light fitted in that way  was usually fitted to the boats we hired in the 1970's and 1980's.
Edited by Ronaldo47
Typos
#223
My understanding is that filament bulbs are the only type that can be used in existing navigation lights in order to produce the  beam shape and sharp cut-off that the regulations require to ensure that both red and green are not seen simultaneously.  It is not possible to produce a led bulb with an essentially point source  that radiates light equally in all directions. There is the "corn cob" construction with multiple LED chips pointing in all directions, but this is physically large and will produce a different beam distribution when used in a reflective and refractive optical system designed for a point source filament bulb.
LEDs are not always suitable drop-on  replacements in other situations. I have mentioned in another thread the short life experienced when using LED bulbs to replace tungsten bulbs in outdoor bulkhead fittings on the heritage raiilway where I volunteer, where supposedly 30,000 hour bulbs controlled by a photocell to only come on at night, have regularly been failing after less than 2 years' service (around 4,000 hours at an average of 12 hours per day).
On getting copies of the manufacturers' data sheets, it transpired that they are not recommended for use in totally enclosed luminaires, because this would result in the shorter life that we have been experiencing in practice. Dismantling some of the failed ones showed severe overheating of the electronic components and printed circuit boards  that such lamps have  crammed into their bases. Last winter I fitted some luminaires with the few now discontinued 'stick' CFL lamps that I had at home, and bought the lowest wattage BC LED lamps I could find,  in the remainder. It will be interesting to see how they fare this winter.
Fortunately the railway has just been donated a large box of a couple of dozen assorted unused CFL lamps that I will use when the LED lamps fail.  The CFL's slow warm-up time does not matter when the lamps are going to be left on continuously for several hours at a stretch, and the light distribution of a CFL, being highest sideways on, is a positive advantage in bulkhead fittings such as ours where the bulb lies vertical. The polar diagrams of many GLS-replacement LEDs show most of the light being directed away from the base, with less of it going sideways, not ideal for illuminating a footpath.
LEDs are fine when used or incorporated in light fittings designed for them, where adequate heat sinking for the electronics can be provided, and there is a better chance of the much vaunted long lives of LEDs actually being realised.
Edited by Ronaldo47
Typos
#224
But even if you have the correct lights, you cannot practically fit them in the correct positions on a narrow boat.
#225
Probably missing them all due to not having a LED tunnel lamp....
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
