Skip to content
Are LED Tunnel Lights Really Necessary
Featured Replies
#226
I was never happy with tunnels, even with an adequate lamp for seeing where I was hoping to go.  My concern was, if somebody had fallen off their boat ahead of me, the chances of me seeing them in the water were negligible.  Clearly the BSS should require a forward steering position for travelling through tunnels?
#227
A few years ago I arrived at Braunston tunnel with no opposing traffic and put my navigation lights and tunnel light on.
Within the first 100 yards the tunnel light flickered on and off a couple of times before determinedly remaining off.
As luck would have it , Jane was in the boat with cabin lights on and I discovered the headlight was no great loss.
Travelling at a brisk walking pace it's not really necessary to see very far ahead, and the cabin  and navi' lights  illuminated the walls sufficiently.
Of course I was fortunate no other boats were in there, which is why in my opinion, the headlight is not really for you to see, rather to be seen by others.
Rog
Edited by dogless
#228
Yes you must illuminate the front of your boat so that those coming towards you can see where it starts.
#229
11 hours ago, Ronaldo47 said:
My understanding is that filament bulbs are the only type that can be used in existing navigation lights in order to produce the  beam shape and sharp cut-off that the regulations require to ensure that both red and green are not seen simultaneously.  It is not possible to produce a led bulb with an essentially point source  that radiates light equally in all directions. There is the "corn cob" construction with multiple LED chips pointing in all directions, but this is physically large and will produce a different beam distribution when used in a reflective and refractive optical system designed for a point source filament bulb.
Its OK, his nave lights didn't comply before the LEDs were fitted so nothing has changed
#230
Which of course they can't do if they are being blinded by the light 😄
#231
That's going to take a really long tiller arm, isn't it?:huh:
  • Moderator
#232
Rog
I was once waiting at the entrance of a tunnel too narrow for two narrowboats to pass. Could see a white light inside, so waited. And waited. And waited. Light was getting further away, not closer. Was the stern navigation light, not the tunnel light of the boat inside. Why navigation lights in a tunnel? You are hardly going to have boats heading towards you from the side, where the visible combination of red/green/white is important for determining speed/direction and the correct collision regulations response in the dark.  It would be OK if all canal boats had them and were required to use them in tunnels, but if only a few do, you get the confusion that I saw.
#233
I put them on in tunnels, because if not then, when am I ever going to use them ? 😊
Rog
#235
We have flower pots on the roof with solar lights in them, so going through tunnels I'm lit up like Christmas 🤭
In 21 years the only time I've used navi' lights in earnest was on a cold February morning in a blizzard when we had to move to Gt Haywood for services.
Couldn't see a damned thing but hoped anyone crazy enough to be moving would see me.
Rog
#236
Rog
 Careful, you will wear them out prematurely... 😂
Edited by cuthound
Phat phingers
#237
When it's dark?   That happens daily ...
Yep, that's what they are for!
#238
Cruise in the dark 😱
Have you run quite mad !
Dark's for alcohol intake surely?
Rog
#239
When a group of us used to hire boats, we usually found we  had to moor up somwhere involving a walk along the towpath to get to the nearest pub. If the boats were pointing in the right direction, the advance guard used to turn on the (dipped) headlight to illuminate the tow path for the others. .
Edited by Ronaldo47
#240
We have a 3 foot long led flood light... if people find it too bright we ask they don't look directly at it 😂
  • 2 weeks later...
#242
On 03/12/2024 at 13:09, Hudds Lad said:
There seems to be a new trend for using nav lights in tunnels, i've noticed a couple of YouTubers do this, maybe those newer boaters who've "done their research" have seen it there and taken it as gospel?
Why wouldn't you, if they're fitted? It costs nothing!
In two-way tunnels I find it helpful if oncoming boats have them; judging distance is much easier than a point light source.
In tight one-way tunnels they conveniently mark the front cabin corners which are most at risk of being scraped.
Edited by Francis Herne
#243
I never used to turn ours on in tunnels until the time I met a boat coming the other way with theirs turned on and thought how much easier it was to work out where their boat was.  Since then I now turn ours on purely for the reason it may help the boat coming the other way.
#244
But the full set projects a white light to the rear so anyone waiting to enter a one way tunnel thinks it is a boat coming towards them. Dammed inconsiderate, I say, at least stick a couple of red Quality Street wrappers over the stern light lens for tunnel work
Edited by Tony Brooks
#245
1 minute ago, Tony Brooks said:
But he full set projects a white light to the rear so anyone waiting to enter a one way tunnel thinks it is a boat coming towards them. Dammed inconsiderate, I say, at least stick a couple of red Qualitystreet wrappers over the stern light lens for tunnel work
What, a Port navigation light seemingly coming towards you? That'd confuse:huh:
#246
I only have the front red/green ones, I guess that means my boat is illegal and will be impounded and crushed... 😞
#247
but no starboard one, which you should see from a distance, and no white light above and between the two.
Better still, take the bulb out until its use is mandatory.
#248
Because of the increase of kayak/canoe/paddleboard pilots with headtorches in tunnels as has been mentioned by others.
I agree they can be useful if coming towards you for the reason you suggest, but it's the being half a tunnel behind someone, or being that someone, with them on that gives me pause.
I've a sneaky suspicion some builders or fitters wire the nav lights to the same switch as the tunnel light, as it does seem to be newer boats that do it.
#249
My tunnel light is there to illuminate the roof.
I have a torch  on the stern, which illuminates .my legs, so anyone behind can see me, and judge the distance.and direction.
I probably would have my big torch to shine in his eyes if he came any closer ;)
I trust I go slower any canoes. Im bigger than them so they will have to keep out of my way!
Edited by LadyG
#250
Separate switches on mine...
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
