Onewheeler Posted October 20, 2020 Report Share Posted October 20, 2020 I'm fitting a new rope seal to the door of my Boatman stove. Would one normally add some cement or high temperature mastic to hold it in place? Martin/ Link to comment Share on other sites More sharing options...
bizzard Posted October 20, 2020 Report Share Posted October 20, 2020 Just now, Onewheeler said: I'm fitting a new rope seal to the door of my Boatman stove. Would one normally add some cement or high temperature mastic to hold it in place? Martin/ You can get the correct glue to do this, but But I've found with mine that if the rope groove it scraped and cleaned out properly the rope will stay put on its own and will soon get impregnated with a bit of goo from the fire anyway which will hold it there. Link to comment Share on other sites More sharing options...
matty40s Posted October 20, 2020 Report Share Posted October 20, 2020 Just happen to have some next to me... Link to comment Share on other sites More sharing options...
bizzard Posted October 20, 2020 Report Share Posted October 20, 2020 Just now, matty40s said: Just happen to have some next to me... I've got a little bottle too which came with some rope, that I didn't use. Link to comment Share on other sites More sharing options...
pete.i Posted October 20, 2020 Report Share Posted October 20, 2020 Yes it should be glued in and, usually the rope comes with the glue or at least the place you bought the rope from should have given you choice of buying the glue with the rope. Whichever it needs to be glued in with the correct glue otherwise it WILL fall out. Link to comment Share on other sites More sharing options...
jonesthenuke Posted October 20, 2020 Report Share Posted October 20, 2020 I use silicone, just enough to hold it. Once fired it happily stays in place. Link to comment Share on other sites More sharing options...
Onewheeler Posted October 20, 2020 Author Report Share Posted October 20, 2020 Ta chaps or whatever you identify as. I'll find some of the high temperature mastic stuff. There's a tube somewhere in the garage. Link to comment Share on other sites More sharing options...
Tracy D'arth Posted October 20, 2020 Report Share Posted October 20, 2020 I suspect that the glue is isinglass. Link to comment Share on other sites More sharing options...
Onewheeler Posted October 20, 2020 Author Report Share Posted October 20, 2020 3 minutes ago, Tracy D'arth said: I suspect that the glue is isinglass. Can't have that, the missus has veggie tendencies. It doesn't stop her drinking beer though. Link to comment Share on other sites More sharing options...
Rickent Posted October 20, 2020 Report Share Posted October 20, 2020 2 hours ago, matty40s said: Just happen to have some next to me... snap. Link to comment Share on other sites More sharing options...
Machpoint005 Posted October 20, 2020 Report Share Posted October 20, 2020 2 hours ago, Onewheeler said: Can't have that, the missus has veggie tendencies. It doesn't stop her drinking beer though. She needs to try the products of Marble Beers, Manchester (well, Salford now, actually). The company has never used isinglass. Link to comment Share on other sites More sharing options...
Kiwidad Posted October 20, 2020 Report Share Posted October 20, 2020 4 hours ago, matty40s said: Just happen to have some next to me... That doesn’t look like my bote Link to comment Share on other sites More sharing options...
matty40s Posted October 20, 2020 Report Share Posted October 20, 2020 2 minutes ago, Kiwidad said: That doesn’t look like my bote Dunno, the woodworm is pretty bad.... Link to comment Share on other sites More sharing options...
Ex Brummie Posted October 20, 2020 Report Share Posted October 20, 2020 Screwfix No Nonsense external leak sealer is cheaper, and keeps when reclosed. I use it to restick Aga lid seals. It's also useful in many other instances, like sealing leaks. Link to comment Share on other sites More sharing options...
Kiwidad Posted October 20, 2020 Report Share Posted October 20, 2020 2 hours ago, matty40s said: Dunno, the woodworm is pretty bad.... Ah, sorry I didn’t realise you were working on the bottom of the bote Link to comment Share on other sites More sharing options...
