cornishdave
4g router/hotspot
Hi,
I'm wondering if anyone can recommend a specific 4g router/Wi-Fi hotspot device, ideally one that will runs on battery and also will take an external antenna? Or failing that, does sticking one to a window get over the Faraday cage problem of being in a metal tube?
Cheers
Dave
Share this post
we run a Huawei E5573 that i picked up 2nd hand a couple of years ago for about £20.
It has an internal battery but to be honest its usually run off a USB cable plugged into a 12v cigar socket.
Its blu-tacked to the window in the saloon and usually performs well, but i have recently bought a pair of cheap aerials for it as it has two TS9 sockets which worked well last time out on the boat. If it was solely our boat i'd look at a more permanent solution and spend a bit more.
i think @Jen-in-Wellies had problems with one overheating in a window so be careful of direct sunlight
Share this post
It does with my phone which I use as my WiFi hotspot for my laptop, tablet and for streaming TV, music and radio.  Actually, it doesn't need to be in the window half of the time.  I cruise most days though, so if I'm ever in an area with poor net access I can wait 'til tomorrow - this is why I don't feel any need to go for any device other than the phone.  A Faraday Cage with glass windows isn't a very effective Faraday Cage.
Share this post
Yes, a south facing window on the hottest day of that year killed it. As @Sea Dog says, a Faraday cage with glass windows isn't that effective. Window mounting helps if the signal is poor, but in a strong signal area, anywhere works pretty much.
Jen
Share this post
Because our cruising range is a lot wider than most on here, I've timkered around wil all sorts of kit.
For our requirements - "web browsing", the popular Huawei E5372 type(s) are adequate.
I've played around with
dongles in the window
flat aerials also in a window
For consistent results I find that a whip aerial on the roof works best 'almost anywhere'.
You can spend a lot of money on multi elements in a box and whizzy routers from different manufacturers (though I suspect most of them contain "WahWei" chips). The real determinant is "location, location, location". Service providers concentrate their efforts on customers in towns and cities - folks moored in a tin box in a ditch at or below ground level are not a high revenue prospect, thus "we" get poor service...
Share this post
Wi Fi thingy in my window mounted upon Meccano bracket. good reception.
Share this post
3 minutes ago, bizzard said:
imageproxy.php?img=&key=fba7ffdd30274950imageproxy.php?img=&key=fba7ffdd30274950imageproxy.php?img=&key=fba7ffdd30274950Wi Fi thingy in my window mounted upon Meccano bracket. good reception.
Yesah - but you're in Boyd Gibbins land - so you've got a good signal...
Share this post
I can see the mast from here, just by the railway.  But it's good everywhere, it's mobile with it's own battery, lasts about 4 hours, had it 3 years. The dangling lead is to USB charge it.
   The bracket has stand off Meccano bits at the top so that the curtain can be drawn across behind it, the signal gets through the curtain as well as the glass.
Edited by bizzard
Share this post
Stacks of s/h Meccano on ebay cheap, buy some it will open up a fantastic new world for you and keep you fully occupied making things during lockdowns and the winter.
Share this post
I know this is trivial.  Meccano trivet upon my stove, on which I dry my nuts, wood and socks before feeding them into the furnace.  Painted in metal primer.
Edited by bizzard
Share this post
That's something new!, Never throught that you were into hardcore Masochism.
Share this post
Frank Hornby was a very forward thinking chap. He selected the pitch and size of the holes in Meccano  in 1898 so as to easily let 4G and WiFi signals pass through. Will it block 5G signals though? Will conspiracy theorists be wearing home made Meccano suits of armour to protect themselves from the Covid and the mind control?
Jen 😁
  • Haha 2
Share this post
Jen 😁
Indeed, Frank did think about the future and thought a lot about Wi Fi signals and stuff. So much so that he made it clear that in future when plastics  technology arrives thin plastic plates to let the signals through were to be manufactured, as just the holes wouldn't be sufficient in metal plates.  The blue and yellow back plates behind ,my dongle thingy are the later thin plastic ones. :closedeyes:
Share this post
Jen 😁
Indeed, Frank did think about the future and thought a lot about Wi Fi signals and stuff. So much so that he made it clear that in future when plastics  technology arrives thin plastic plates to let the signals through were to be manufactured, as just the holes wouldn't be sufficient in metal plates.  The blue and yellow back plates behind ,my dongle thingy are the later thin plastic ones. :closedeyes:  He actually visualized 10G to match his biggest No 10 Meccano construction set.
Share this post
3 hours ago, cornishdave said:
Hi,
Cheers
Dave
Hope you will be suitably inspired by all this highly technical Wi FI nollidge, cornishdave.  :unsure:
Share this post
I am thanks, all very helpful and interesting.
I'm also impressed with your mecanno contraption - it reminds me of the stereo mount I cobbled together in my very first car using the same materials
Cheers
Share this post
I had Trix stuff - much better stampings with less agricultural fixings.
I wonder what happened to them?.......
Share this post
I don't think they lasted long, very limited differing bits and pieces in the range. They're Trix Twin 3 rail 00 gauge model train sets didn't either, Strange looking out of scale loco's and stock.  Not in this country anyway.  Bloddy Gairmans again.
Share this post
Vogue was another metal construction set in the 1950's, similar to Meccano, same red and green colours and pretty well compatible too, could be used together in most cases.
Share this post
16 hours ago, Tracy D'arth said:
I had several Bayko houses at an early age, none of them had WIFI or a router.
Loved Bayko. Probably why grew up to be a builder!
Share this post
