Bobbybass Posted September 23, 2020 Report Share Posted September 23, 2020 Hi all. I posted this photo previously. How do I find out the size of the " string"/tape that I need to pack this gland ... without taking it apart? Or....do I have to take it apart ? ? Thanks all ! Link to comment Share on other sites More sharing options...
Tracy D'arth Posted September 23, 2020 Report Share Posted September 23, 2020 Measure the diameter of the "pusher" the bit that the 2 nuts pushes, Subtract the diameter of the shaft. Divide the answer by 2 gives you the thickness of the packing to buy. Allow enough length for 4 rings around the shaft - shaft diameter times pi . Link to comment Share on other sites More sharing options...
David Mack Posted September 23, 2020 Report Share Posted September 23, 2020 Alternatively, first pump some grease in, then undo the nuts and retract the pusher some way along the prop shaft towards the engine, then try poking the blunt end of different sized drill bits into the gap between the shaft and the stern gland body to find the size of drill which will just go in. That is the size of gland packing you need. Reassemble the gland to keep the water out until you are ready to repack. 2 Link to comment Share on other sites More sharing options...
