Boots'n'all Posted September 17, 2020 Report Share Posted September 17, 2020 My narrow boat has a lister sr3 coupled to lh150 gearbox. Access is terrible to the gearbox I’m struggling to find the drain and lever plug Link to comment Share on other sites More sharing options...
Tony Brooks Posted September 17, 2020 Report Share Posted September 17, 2020 It may also have a reduction box on the end that is separate from the gearbox oil. Level DIP STICKS are on the starboard side of both boxes and have a fancy knob on top.The drain plugs are at the lowest point on each box in the centre and underneath the boxes. (Long time since I worked on one so I may be wrong about either location ). Don't mix the dip sticks up if you have a reduction box, many do. I think the long dipstick goes in the reduction box (I think) Link to comment Share on other sites More sharing options...
Steve56 Posted September 17, 2020 Report Share Posted September 17, 2020 There is also a small drain plug in the aluminium adaptor which allows the last bit of oil to be removed from below the oil pump. Also the gearbox drain plug has a built in magnet which will need cleaning when removed. Link to comment Share on other sites More sharing options...
TheBiscuits Posted September 17, 2020 Report Share Posted September 17, 2020 4 hours ago, Steve56 said: Also the gearbox drain plug has a built in magnet which will need cleaning when removed. Checking, surely? If it always needs bits of metal cleaning off then Bad ThingsTM are happening inside the gearbox! Link to comment Share on other sites More sharing options...
Tony Brooks Posted September 18, 2020 Report Share Posted September 18, 2020 7 hours ago, TheBiscuits said: Checking, surely? If it always needs bits of metal cleaning off then Bad ThingsTM are happening inside the gearbox! I think that depends upon the degree and type of debris. I don't think I ever did an oil change on a Mini that did not have some metallic debris on the plug. A little bit of very dust like "mud" would not worry me but en equally small amount of gritty it would. Its a bit like looking after batteries in that you need to decide what is normal for your boat and then start to worry if it becomes abnormal. With those sun gears for reverse I don't think you will ever take a completely clean plug out. Link to comment Share on other sites More sharing options...
