matty40s
Needs Tidying Up Project Widebeam
35 minutes ago, matty40s said:
How polite you are. I've rarely seen a boat looking so knackered.
I realise that it's been under water, but does that explain the piles of rubble inside?
Share this post
Typical Collingwood fitout.....
  • Haha 2
Share this post
1 hour ago, David Mack said:
It's got a big dint in the stern.
That will buff out.
N
Share this post
Sad to see a boat like that.
I don't thinks its rubble is it?? Looks like the remnants of the interior (including wall boards and insulation)  mixed with a bit of sludge from the Thames.
Share this post
Possibly ballast too. Rubble usually started life as something useful,, hence the expression "reduced to rubble".
Edited by Athy
Share this post
Looks like they have covered the problem of it turning up in the same place and going adrift again.
"Any potential purchaser should have means and proof of being able to remove this boat to a suitable refurbishment centre within 2 weeks of the sale ending.  Failure to provide such proof at the time of the close of the sale will result in the cancelation of the sale, loss of deposit & the craft will be instantly offered to the under bidder, Direct from Environment Agency, On Site "
What a sensible clause to put in. Environment Agency playing hard ball for a change... About time.
Edited by magnetman
Share this post
3 minutes ago, magnetman said:
It was only under water for a few weeks it's basically a shell with a bit of work to tidy it out.
You are optimisitic!
Engine unknown, gearbox probably alright but unknown, electrics all scrap, doesn't look like there was much fit out but what there is is scrap, no windows, superstructure and hull damaged and all submerged for a few weeks.
Wouldn't be my first choice as a project boat!!
Share this post
Well its a better project than many, better project than the old wooden joey boat I started on , A couple of weeks really hard work would make a really big difference, its got stern gear, prop, gearbox (engines probably not worth the bother) and as for that big dent in the stern just fit a ladder in it and say its deliberate for reboarding if you fall in.
Share this post
Given it's a 2018 engine that's probably not got a huge number of hours on it I'd be tempted to take it apart and see what sort of state it's in before condemning it.
To be honest clearing out the inside of the boat and giving it the attentions of a pressure washer might result in something that doesn't look too shabby.
Would have to be pretty cheap though, but I've seen people try to fix up much worse prospects than this one!
Share this post
Get @W+T on the job.
I've seen his boats ...
Share this post
The boat is near me and I think quite new. Therefore the basic shell will be OK keep the dent as a feature. I think in reality it is worth very little. Lets say 50% of a new shell less costs of storage, lifting, clearing up, painting etc. If you have to pay Thames prices for storage/mooring I think about 5-6K max. It might well become a work boat as others have in the past so I think it will go that way in the end.
Share this post
Engines that have been under water are often OK providing you don't turn them over before draining the oil out. As they sink, the oil rises up the bores and prevents rusting.  Saved quite few over the years.
Share this post
It's a 2019 shell. No need to pay Thames mooring/storage - it could easily be towed up the GU. Will need cleaning up inside and out, but then you will have a nearly new shell, and maybe an engine that can be got running. Got to be worth something to someone.
Share this post
Dent in the roof? Dent in the stern?  So dent in the wallet!
Its a good project, if you like that sort of thing. Be interested to know who's shell it is.
Share this post
Surely its just the equivalent of a bare shell.
Shovel out all the crud and you have the makings of a cheap boat.
Strip down the engine clean and it may yet run. If it wasnt running when it went down there is every chance it will be OK. Ok you will need new engine electrics probably and of course domestic electrics too but for anybody who has the skills and the time themselves and doesn't have to pay somebody else to do it I would say its worth a punt.
Share this post
Ta.  Bit of filler and a lick of paint it will be better than new then.
Preferable to a fire salvage though.
Fire brigade are very over zealous, have they had a hand in the salvage?  If so its lucky that they have not cut the roof off!
Share this post
The paint job looks pretty cool to me. Maybe it will set a new trend.
The Fire Brigade often seem to sink boats but this one was sunk when it was hauled off Sunbury Weir by a tug during the winter floods. It had been sitting against the guard piles for quite a while and then for some reason a tug was sent out to retrieve it. I suspect because it had started to interact with part of the weir structure but I don't know this for sure.
Screenshot_2020-09-17-11-47-29-838_com.android.chrome.png.156c192376491b3353df93f87ac3fbc4.png
Not my photo I found it on canalworld.
Edited by magnetman
Share this post
