Steph H
Marina entrances
There is probably an explanation for this but I can't think of it.
Why are marina entrances so narrow?
Share this post
Because normally the marina is dug out before connection to the canal. When the final removal of the bund takes place, it is normally only a diggers stretch from both sides wide.
Share this post
That sounds like it could be true, but in reality its so people can watch you try to navigate in. Some Marina's I swear have score cards that they hand out...  :)
I'd love to see a new Marina when they let the water in - it must be up there with one of the best parts of a job!  I presume they have to do it slowly though so the local canal doesn't run dry ... maybe have people at any locks also to open paddles??
Share this post
It is generally done very slowly usually by pump , and the bund is left in place whilst it fills.
Then 2 weeks minimum with no water being let in to test the waterproofness of the construction.
Only then is the bund removed...very unspectacular.
Share this post
ok i take it back, sounds like its a bit boring.... i had visions of having a surfboard handy!!
Share this post
And CRT require that before the marina is finally connected, a leakage test is carried out to show that it is watertight. To do this two sets of stop planks are placed across the entrance and the space between them is pumped out (so it is clear no water is leaking through the planks). This is maintained for a period of time, and the drop in level of the marina has to be less than a certain amount.
So a marina entrance is needed which can take two sets of stop planks. And that will be relatively narrow.
Share this post
Perhaps the gap is narrow  so the gap could be  filled in at relatively modest cost if the marina should cease to be  a marina?
Share this post
Also allows for stop planks/coffer dams to be installed easily should the main canal need to be drained for any reason.
Share this post
18 minutes ago, mrsmelly said:
All wrong so far. It's actually to stop numpties with wide beams escaping out of the marina when moored in stupid locations like the North Oxford etc.
Beat me to it by 17 minutes.
  • Happy 2
Share this post
No, completely wrong. Here is a picture of how the stop planks for a new marina are usually "removed" and the marina filled. 😀
  • Haha 3
Share this post
When Peter Topping had Cowroast Marina dug out he bought a rather nice historic bridge to span the entrance.  I can't remember where it originally came from.  This determined the width of the entrance.
A few years ago we nearby moorers watched a widebeam get well and truly stuck in the entrance, because the then owner of Cowroast gave the boater the wrong dimensions.  Oops!
Share this post
Some great replies thank you.
As a fairly new boater I've just found it difficult getting into a marina at times and its rather off putting when marina staff look at you like your an idiot, so just wondered what the reasoning was.
Now when I go into one I'll be marking myself out of 10 and humming the Dam Busters music 🤣🤣
Share this post
Move to Venetian, problem solved! :D
Share this post
17 minutes ago, Steph H said:
>>  As a fairly new boater I've just found it difficult getting into a marina at times and its rather off putting when marina staff look at you like your an idiot, so just wondered what the reasoning was. <<
Don't worry about it. I've seen boats with bow thrusters making a pig's ear of our marina entrance.
It takes practice, and there is only one way to do that!
Edited by Machpoint005
Share this post
When I in the RN and the ship was in dry dock, always interesting to see the sea stopping the dry dock not being a dry dock. Intensional of course. Then the gradual movement of the ship becoming a ship again.
I get the same enjoyment with narrow boats.
Is it just me?
Share this post
Is it just me?
It's certainly good to feel the boat float again, after an odd still week on the blocks in a dry dock.
Share this post
Speaking as an ex marina worker, we aren’t much better at it, especially when there’s an audience of co workers. Some entrances are worse than others, but the only suggestion I could make would be to go as slow as is practical, depending on the strength of the wind or any other factors such as current. Ignore any other boater who wants you to hurry up and do it at your own pace.
There’s one marina I can think of that can only be got into bows first from one direction, if you boat is over 55 ft. We found that out when we got there....
Share this post
Is it just me?
It's just you 🤣
Iirc when lifting in dry dock in Gibraltar after repairs and new props there was little movement. Also I was on the first frigate ever to dock in the new frigate complex at devonport in 77 on HMS Galatea and again smooth as silk. However I spose its to be expected unlike the toy boats we now own lol.
Share this post
Drawing that ammount of water in one go would have a pretty serious effect on the adjoining canal.
Share this post
indeed... Alton Towers moment, until the water runs out... :)
Share this post
There used to be a video of one the newer marinas being filled, but this is the only one I can find now.
Share this post
And Dunchurch Pools had to get special permission to have a wide entrance and long stop planks (to get the fat ones in and out)
Share this post
Lovely - remembering folks of the past, who tend to get forgotten (B.W.'s daughter was in a snall music group in which we sang - thus a more related reminder)
Share this post
