MajorJones
Help needed to identify the material
Hi guys!
I'm trying to identify a material that I see now more and more often on the new builds - it looks like tongue and groove cladding boards, but actually it's just a visual effect and it's a panel, I'm not even sure it's a wood as from the cut it looks like some sort of compressed foam with the layer on top. I've attached a couple of photos. Any ideas?
Share this post
It looks like the material used in modern kitchen units, which I think is MDF. Someone here will be sure to know for certain though.
Share this post
Thank you! I feel so stupid now, it must be MDF primed beaded panel 🤦‍♂️
Share this post
It could possibly be machine routed in to the plywood. My boat has this on the ply for the ceiling and the walls below the gunwale, though it is a single V shaped groove for each "plank" edge, not the more complex pattern you have shown.
Jen
Share this post
Can confirm now! MDF panel - available everywhere (Travis, Wicks, etc). 20 quid per m2 - cheap, but looks nice - I understand now why so many new builds are using it.
Thank you very much guys for your help!
Share this post
Note that is described as moisture resistant, not moisture proof.  Do not let if get very wet for any length of time or if will turn back into Weetabix.
All MDF is filthy stuff to work- you will want the proper PPE.
N
Share this post
N
I've worked with moisture resistant MDF before - won't work without PPE, the dust is toxic as hell.🤝
Share this post
2 hours ago, Paul Gwilliams said:
There are pvc versions available specifically designed for bathrooms and shower cubicles. All sorts of effects wood, marble and glitter
We are going to use it to redo shower and boat ceiling
https://www.claddingwarehouse.co.uk/pvc-k-panel-cladding-sheet-white
There are plenty of designs ( i.e. https://www.dbsbathrooms.co.uk/bathroom-panels/wall-panels ) - but I'm after specifically one that looks like painted tongue and groove - I really like how it looks under the gunwale (and above gunwale I plan to use marine leatherette in the same colour tone).
Share this post
Have you considered painting some matchboarding?  You can still make it into panels by attaching it to some 6mm ply sheets.
Share this post
Don't really see a point to have a real wood for under the gunwales as I want to have it in solid white to be honest.  I want to have some wooden accents in the design, but mostly I prefer white and airy spaces.
Share this post
N
Love the Weetabix but so very true, no matter how careful you are the lower section will sooner or later get damp at the bottom, and the upper section somewhere will have a window leak.  Plastic coated foam won't go to weetabix but Greenville tower was clad in that looked good but... Not to mention toxic fumes wood smoke is nasty but not in itself poisonous.
Share this post
8 hours ago, MajorJones said:
Don't really see a point to have a real wood for under the gunwales...
It avoids the Weetabix risk.
Share this post
I see so many new build using what looks like MDF - have we wrongly identified the material used or do builders just don't care what will happen with the interior eventually?
Share this post
It could be either.  A quality fitout would be real wood, painted white if required or varnished according to taste. A cheaper fitout would be MDF.
Share this post
