Hearth size, BS and BSS
cairanvanrooyen
My boat was built in 2002, it had an old Morso, which was knackered and we are completely refitting the interior, including a new Morso and flue.
BS 8511:2010 has a requirement for a substantial hearth, where it needs to project at least 225mm in front of the stove, which is far too much for our NB.
So...
Question 1 - do we strictly need to comply with BS8511:2010 for installing a new stove in our old NB, which had a stove fitted previously, which did not comply with aforementioned BS?
Question 2 - if we install a smaller hearth will this affect the BSS? (I cannot see from the "BSS Examination Checking Procedures for Privately Owned and Managed Vessels" document, where this would be a problem.
Question 3 - we are proposing to have a single skin solid steel flue installed, as the existing, is this a problem?
Question 4 - to suit existing penetrations, we are installing a 5" flue, instead of 6" (outlet size on the Morso)
No to all 4.
As for 2 specifically, as far as I'm aware it's just common sense.  The examiner wants to be sure that it's safe, simply to stop your boat catching fire.
When I say no to all 4 I mean, that all 4 are no problem.
So...
I have just had a BSS. The Morso does not have an extended hearth. This may not be the case with newly fitted stoves. I would suggest you make (extend) the hearth floor-level and no higher than existing floor levels, but of a fire resistant material. It is obviously a tripping hazard, if it is too pronounced. It depends a lot on the fire's orientation in the space of a saloon, or whatever.
Edited by Higgs
