Terminology
Dartagnan
36 minutes ago, Tam & Di said:
You wrote "locker behind her" - do you mean behind her when she is steering? Technically that is called the aft peak, and the triangular top is the stern deck. I've heard boat people refer to it as 'the starn' but nothing more specific. Although a modern boat with a forward well deck will have drainage scuppers and possibly fitted with a non-return valve I've never encountered a drain in the hatches of a working butty - they'd be pretty much at water level when you're loaded.
Tam
Chatting to Mike earlier on this evening and he has confirmed that.
Edited by Ray T
38 minutes ago, Tam & Di said:
I have various construction drawings including a copy of 1/2" to 1 foot plans copied from GUCCC originals and it is marked prosaically as 'steerage cockpit', but boat people always referred to it as 'the hatches' as said. One of the drawings calls the shackle the 'hawser shackle', but the copy dated January 1936 for a large Yarwoods ('town' class) motor has them as 'Answer pin and shackle. On the odd occasion I've had cause to write the term I've written 'anser pin'.
Tam
Thanks Tam
The points above relate to a butty that has been converted to a motor but I have also seen drains in an ex-working butty, albeit not necessarily a feature of the original build so they could have been added during restoration.  In both cases they divert water in to the bilge for the pump to deal with.  The "locker" now contains a weedhatch hence the need to correctly describe its location.
Message crossed ?
Thanks Ray.  In the cases I have seen they must have been added as part of a restoration/conversion and rely on a bilge pump.
Dumb question, I assume butties were originally without stern bilge pumps because there was no stern tube that would let water in? Where pumps were fitted, I assume they were hand pumps?
No question is dumb.
As far as I am aware the only pumps working boats had in/on them were hand pumps to pump out the hold.
Not my picture but when Sickle was owned by "The Parrotts."
The pump is just in front of the cabin bulkhead.
Whether the bilge in a motor was connected through to the hold I know not, I will have to resort to a drawing.
I think the only electrics working boats had were an accumulator to work the tunnel light and possibly a "wireless."
The accumulator would be exchanged at a depot as and when needed.
Edited by Ray T
There were plunger pumps with leather washers in the back end of the hold (i.e. immediately forward of the butty cabin or motor enginehole). However the bulkhead between the butty cabin and hold was seldom watertight and you load down be the head so any water runs forward. Otherwise you baled out with a scoop of some kind - a dustpan works very well.
Tam
Ray's photo of Sickle shows the pump very well. The motor's bulkhead should be watertight or there is the possibility of contamination of the crago with oily water.
Edited by Tam & Di
crossed post with Ray
On Fulbourne and Belfast the bulkheads front and back of the engine room are watertight down to the bottom plate, so you have three separate bilges - hold, engine room and back cabin. I suspect this is the case for all the iron/steel GU motors.
G.U. motors had an engine driven bilge pump, although i have no idea how they were operated. There is an outlet in the engine room which had been filled with lead at some stage, on the opposite side to the raw cooling outlet.
The pumps on Fulbourne's National: bilge pump on the left, cooling water pump on the right. The steel wheel to the left of the bilge pump can be slid to the right to engage the pump drive - it should stay engaged but Fulbourne's drops out after a couple of minutes and you have to hold it in mesh to keep the pump going. (Photo: Tim Lewis)
Edited by David Mack
Tam
I wonder if somebody wrote down 'awser pin and their handwriting was poor so it was read as 'anser pin and the person writing it down as 'anser pin had some sort of seniority indicating they must have known what they were talkin' about.
It could be that simple.
Or like happened on lots of old censor forms where the chap writing it down spoke with a somewhat different accent to the chap who couldn't read and write was telling him
I think it would have to be written otherwise why would it get changed from the word "awser" to "anser".
Mind you there are a lot of dialects and probably even more in the olde days so you could easily be right about that.
I talk with a Norfolk accent, I find it almost impossible to spell words by sounding them out as I don't sound them correctly. If you were writing something for me and I said "Ah Bore" what would you write down?
To me in Tipton they speak a foreign language if I had to write what some of them were saying it would be interesting
10 hours ago, ditchcrawler said:
 . . . . as I don't sound them correctly.
Perfectly correct for Norfolk! Don't change.
I think magnetmans "awser" (sounds like hawser with the 'aitch dropped) should be 'answer' with the w dropped - anser. Changes the sound from 'a' as in apple, to 'a' as in aunt. But it will sound different depending on what part of the country you are from. (Is it a country any more - nah, let's not answer that one. Stick to what we knew - it's more comfortable).
The answer is "Yes boy"
To follow on from that I have just snipped this from Facebook. Now imagine you were a scholar from London doing a write up of a Norfolk Gardner and listening to where he kept his spade image.png.03e325f6f95c94cf791f543d68398249.png
