helen1 Posted August 17, 2020 Report Share Posted August 17, 2020 Hy please can someone help ,,my boat has been completely rebuilt and its time to buy the appliances i need a shower enclosure 1700 high which is proving impossible to find and a lpg hob which again i cannot find , please can someone point me in the right direction for appliances Link to comment Share on other sites More sharing options...
Rob-M Posted August 17, 2020 Report Share Posted August 17, 2020 Have you looked at Midland Chandler's, https://www.midlandchandlers.co.uk/ Link to comment Share on other sites More sharing options...
helen1 Posted August 17, 2020 Author Report Share Posted August 17, 2020 thankyou rob , yes i have but i need a black hob which they dont do and they dont do shower enlosures Link to comment Share on other sites More sharing options...
Chris-B Posted August 17, 2020 Report Share Posted August 17, 2020 Appliance warehouse at bunny notts have loads of appliances with lpg conversion jets Link to comment Share on other sites More sharing options...
WotEver Posted August 17, 2020 Report Share Posted August 17, 2020 3 minutes ago, helen1 said: thankyou rob , yes i have but i need a black hob which they dont do... I did a really quick Google for ‘black lpg hob’ and had a bunch of hits. Anything specific you need? This one’s a sensible price: https://www.amazon.co.uk/dp/B00TIMVJRO/ref=cm_sw_r_cp_api_i_7iVoFbMKZ1S3Y Link to comment Share on other sites More sharing options...
helen1 Posted August 17, 2020 Author Report Share Posted August 17, 2020 5 minutes ago, Chris-B said: Appliance warehouse at bunny notts have loads of appliances with lpg conversion jets thankyou so much im looking at those now x Link to comment Share on other sites More sharing options...
Rob-M Posted August 17, 2020 Report Share Posted August 17, 2020 2 minutes ago, WotEver said: I did a really quick Google for ‘black lpg hob’ and had a bunch of hits. Anything specific you need? This one’s a sensible price: https://www.amazon.co.uk/dp/B00TIMVJRO/ref=cm_sw_r_cp_api_i_7iVoFbMKZ1S3Y That's very helpful of you ? 1 Link to comment Share on other sites More sharing options...
Guest Posted August 17, 2020 Report Share Posted August 17, 2020 1 minute ago, Rob-M said: That's very helpful of you ? Agreed. Link to comment Share on other sites More sharing options...
helen1 Posted August 17, 2020 Author Report Share Posted August 17, 2020 2 minutes ago, WotEver said: I did a really quick Google for ‘black lpg hob’ and had a bunch of hits. Anything specific you need? This one’s a sensible price: https://www.amazon.co.uk/dp/B00TIMVJRO/ref=cm_sw_r_cp_api_i_7iVoFbMKZ1S3Y I know this is why its so confusing my boat builder said im not allowed a 15mm inlet pipe which is what they all are, I have to find a 8mm inlet pipe and I just cant find one ?? Link to comment Share on other sites More sharing options...
Tracy D'arth Posted August 17, 2020 Report Share Posted August 17, 2020 You reduce the hob connection down to suit the gas pipe, standard arrangement. 1 Link to comment Share on other sites More sharing options...
helen1 Posted August 17, 2020 Author Report Share Posted August 17, 2020 Just now, Tracy D'arth said: You reduce the hob connection down to suit the gas pipe, standard arrangement. really? my boatbuilder is saying i cant do that as when the BSC is done it wont pass also the gas will be half the pressure if we add a connector (is that true ?) Link to comment Share on other sites More sharing options...
Tracy D'arth Posted August 17, 2020 Report Share Posted August 17, 2020 (edited) 5 minutes ago, helen1 said: really? my boatbuilder is saying i cant do that as when the BSC is done it wont pass also the gas will be half the pressure if we add a connector (is that true ?) Bollony, the pressure at the hob depends on the pressure regulator on the bottle and the proper size of pipe. The pressure using bottled gas is higher than natural gas in a house so the pipe can be smaller. I don't think your boat builder understands gas, is he a Gas Safe fitter with the correct LPG for boats card? He should be to be doing any gas work. Edited August 17, 2020 by Tracy D'arth 1 1 Link to comment Share on other sites More sharing options...
helen1 Posted August 17, 2020 Author Report Share Posted August 17, 2020 2 minutes ago, Tracy D'arth said: Bollony, the pressure at the hob depends on the pressure regulator on the bottle and the proper size of pipe. The pressure using bottled gas is higher than natural gas in a house so the pipe can be smaller. I don't think your boat builder understands gas, is he a Gas Safe fitter with the correct LPG for boats card? He should be to be doing any gas work. i feel so relieved if thats the case as i just cant understand the inlet pipe situation lol , im going to check with him again tomorrrow thankyou so much Link to comment Share on other sites More sharing options...
Tracy D'arth Posted August 17, 2020 Report Share Posted August 17, 2020 Just now, helen1 said: i feel so relieved if thats the case as i just cant understand the inlet pipe situation lol , im going to check with him again tomorrrow thankyou so much Gas appliances intended for natural gas in houses are fitted with connections large enough for the normal rigid copper pipe used in houses or for the flexible hoses and bayonet connectors because the the pressure is lower and the pipe runs longer than on a boat. If you buy a natural gas appliance you need the correct smaller jets for every burner to convert it to LPG at a higher pressure and calorific value. So ensure the appliance is convertible and has the correct bits with it before you buy. Link to comment Share on other sites More sharing options...
helen1 Posted August 17, 2020 Author Report Share Posted August 17, 2020 2 minutes ago, Tracy D'arth said: Gas appliances intended for natural gas in houses are fitted with connections large enough for the normal rigid copper pipe used in houses or for the flexible hoses and bayonet connectors because the the pressure is lower and the pipe runs longer than on a boat. If you buy a natural gas appliance you need the correct smaller jets for every burner to convert it to LPG at a higher pressure and calorific value. So ensure the appliance is convertible and has the correct bits with it before you buy. thankyou so much Link to comment Share on other sites More sharing options...
zenataomm Posted August 17, 2020 Report Share Posted August 17, 2020 48 minutes ago, Tracy D'arth said: He should be to be doing any gas work. I think you wanted to say he shouldn't Link to comment Share on other sites More sharing options...
WotEver Posted August 17, 2020 Report Share Posted August 17, 2020 @helen1 what other gas appliances will be fed by this 10mm pipe? Link to comment Share on other sites More sharing options...
Bod Posted August 18, 2020 Report Share Posted August 18, 2020 All boat gas appliances must have Flame Failure devices fitted. Should the flame be blown out the gas is automatically cut off. This will be checked on the BSS safety check, missing or non working FFd's will be a failure. Not all domestic appliances have these fitted, so be careful when buying. Bod. Link to comment Share on other sites More sharing options...
WotEver Posted August 18, 2020 Report Share Posted August 18, 2020 9 minutes ago, Bod said: Not all domestic appliances have these fitted Could you show me such an example? I’ve not seen a domestic appliance without ffd for years. This could be because they’re compulsory in flats. 1 Link to comment Share on other sites More sharing options...
nicknorman Posted August 18, 2020 Report Share Posted August 18, 2020 9 minutes ago, WotEver said: Could you show me such an example? I’ve not seen a domestic appliance without ffd for years. This could be because they’re compulsory in flats. Agreed, but probably still worth checking. There might be the odd old-design thing out there gathering dust in some warehouse. 2 Link to comment Share on other sites More sharing options...
pearley Posted August 18, 2020 Report Share Posted August 18, 2020 1700 mm showers here http://www.wesleywindows.co.uk/store/1700mm-high-shower-doors.html Link to comment Share on other sites More sharing options...
Tony Brooks Posted August 18, 2020 Report Share Posted August 18, 2020 35 minutes ago, nicknorman said: Agreed, but probably still worth checking. There might be the odd old-design thing out there gathering dust in some warehouse. and there may very well be substandard stuff being passed of by the likes of Amazon & EBay, even more from social media sites that allow selling. Link to comment Share on other sites More sharing options...
Tracy D'arth Posted August 18, 2020 Report Share Posted August 18, 2020 10 hours ago, zenataomm said: I think you wanted to say he shouldn't No. Please read it again, he should be to be doing gas work. Link to comment Share on other sites More sharing options...
Chris G Posted August 18, 2020 Report Share Posted August 18, 2020 12 hours ago, helen1 said: i need a shower enclosure 1700 high Could try Wesley Marine Windows, http://www.wesleywindows.co.uk/index.php?id=3 . They do shower doors 1600, 1700 & 1800mm high. Link to comment Share on other sites More sharing options...
