tree monkey
Wire crimps
14 minutes ago, BEngo said:
Three pronged tool AKA "virgin stretchers"?
Them’s the ones :D
Share this post
17 hours ago, Ray T said:
These are used in the Low voltage looms of railway carriages and sections. It takes a bit of knack to use them, but no worse than you might expect, when trying to melt solder through a plastic sheath. 500 c (heat gun), or there abouts.
Never saw them used to join cable, but mostly to add a drain wire on a screened cable. Joining wire was not generally acceptable. Short cable was completely stripped out and replaced.
Edited by Higgs
Share this post
12 minutes ago, Alan de Enfield said:
They were (are) also used for castrating lambs
Those rubber rings are so very very small
Share this post
2 hours ago, WotEver said:
Oooh, remember those expanding rubber sleeves and the three-pronged tool for expanding them?  I lent mine out once, never to be seen again.
The pink/black rubber sleeves were neoprene and often lubricated with "Hellerman Oil" after 30 years or so the combination of oil and sleeve become slightly conductive, leading to all sorts of interesting behaviour in complex kit (Think tightly packed connectors, military style). The nuclear industry spent millions fixing this.
Share this post
If used on a light coloured cable it would also discolour it; the discolouration slowly migrating along the insulation.
Share this post
Virgin urgers  was our name for them
Edited by Loddon
Share this post
On 29/07/2020 at 18:41, tree monkey said:
Thanks,  but I've got one of them, it's the doobrie thingies that you crimp with the crimper I was wondering about
Cable lugs or crimp terminals are what you want.
Share this post
On 29/07/2020 at 19:16, BEngo said:
https://www.vehiclewiringproducts.co.uk/c-54-kits/c-183-terminal-kits/c-133-pre-insulated-terminal-kits/p-1131-heatseal-terminal-kit
That should do what you want, and they sell replacement crimps in small quantities when you run out of the popular ones (blue 6.3 mm female first, usually).  As before check these crimps are right for your tool.(ooh matron!)
N
Sorry to be obtuse but do you crimp the metal with a proper tool and then use the heat gun to seal it?
Share this post
That is the idea.
If you were really,  really careful I can see no reason why it could not be done the other way round, but cannot see any advantage to doing it that way.
N
Share this post
Yes, sadly the heat shrink sleeve capable of firmly crushing a lug onto a cable has yet to be invented. 😁🤣
Share this post
Middle of (my) Aldi last night - a cable crimper kit. Crimper plus a moderate supply of a few varieties of connecter. Mainly red kit in a shrink wrap transparent box. Six or seven quid-ish. Not sure if it was a 'pliers' or a ratchet crimper - tightly packaged.
Share this post
Red and blue fittings, non-ratchet crimp but it's a wire stripper too, £7.99
https://www.aldi.co.uk/workzone-crimping-tool-set/p/800024379304300
Share this post
And the first time you try to crimp anything the pliers will either bend or break. Even if they don’t you won’t have a successful crimp. If that was the only crimper available to me I’d solder the lugs on instead.
Share this post
Two hammers, or carefully with the sideband cutters ...
I don't have one of them, I just provided the link!
Share this post
