Daughter is having gearbox “fun”
gearbox runs fine in reverse, but in forward the shaft turns but only idly, and there is no clunk as it engages.
Once the gearbox ATF is warm it engages OK
box is HBW150
do these use the oil pressure for shifting? Going to try an ATF change to see if it improves
Share this post
Have you checked that the selector lever is moving properly? Could be a n incorrectly set cable.
Share this post
Tried that. No effect
Share this post
If Girth is code for Hurth, then 'worn out clutch' is an oft-reported problem. Generally cheaper to replace than to repair.
Share this post
1 minute ago, matty40s said:
Girth Gearbox..
is it too wide for the boat?
Yeah bluddy autocorrect!
it it a Hurth!
Share this post
Parts are a daft price, the forward clutch pack is required.
Spurious rebuilt boxes are a gambol.
New ones are no better than the one you have, they all fail too often.
Do yourself a favour, fit a new PRM90, straight forward replacement, far far better gearbox. and cheaper than a new Hurth.  Best price I find is Calcutt marine.
Loads of threads here and elsewhere if you search the posts.
TD'
Share this post
TD'
Sounds promising
is the PRM 90 a straight swap, easy enough for the mechanically challenged to perform. With no need to start adjusting engine height etc?
Share this post
7 minutes ago, mayalld said:
Sounds promising
In some cases, yes.  I have never done one but plenty of folk have. It depends on your boat, no 2 are the same.
Do a search on here, there are lots of threads about this.
Ask PRM, they are very helpful, give them a ring in Coventry.
TD'
Share this post
I now have visions of gearboxes springing across a field...
Share this post
Well it amused someone, success!  Spell checkers of the world unite.
Share this post
Hope you got it sorted, sorry I can’t offer any practical advice. But let me say that it was a pleasure encountering you and your family on t’cut. Jeff (who has been a bit up and down with his mood recently) repeatedly commented on how nice everyone was.
Share this post
That is a really nice post, just exactly what the forum is so good at.
Share this post
It was great to meet Nick and Jeff.
Arguments on here whilst sometimes passionate mask the fact that with very very few exceptions it isn’t personal!
i can also vouch for the fact that Jeff, quite apart from his impressive facial hair has working locks down to a fine art. There is a knack to always knowing where to be next to make it work smoothly, and it is great to see in action.
In other news, the gearbox seems to have recovered!
milky ATF suggested water contamination, so we pumped out the ATF, half a liter of red diesel and ran the box for 10 minutes both ways, pumped out the diesel and new ATF.
Running sweetly for now. Slight ATF leak around the selector arm, but not tempted to try to fix that!
Share this post
