Dave 2
Antifreeze turning black
Hi all for some reason my pink antifreeze has started to turn dark pink with a sediment in the expansion tank, engine And boat only 2 years old any ideas welcome.
Share this post
Corrosion inhibitor used up, not concentrated enough and the iron & steel is rusting. Change it forthwith, 33% to 50% concentration.
Share this post
Hi can you help me as the boat has two skin tanks what’s the best way to drain the antifreeze, I’ve done it on vehicles but never a boat.
Share this post
Or possibly the system was only half drained and red and blue coolant in large quantities have mixed which can cause a fine ‘sand’ type of sediment to form.  Flush and refill.
Share this post
Wet and dry vac. Remove lower hose/s and vac out. Flush out with clean water to remove all old AF and sludge.
Mix concentrated AF with water to required concentration before putting it in.  Don't use hard water or water from a water softener. Clean rainwater is OK.
Deionized is better but gets expensive.
Share this post
Its not that bad if you get it from a motor factors, even Tesco sell it by the 5lt container. You could of course buy premixed antifreeze
Share this post
Hello, I'll also need to change my antifreeze soon. How/ where do you correctly dispose of the old mix? I'm used to motorcycles where I typically get a litre at a time, not tens of litres.
Thanks.
Edited by Awayonmyboat
Fat finger problems
Share this post
Thanks.
Contact your Local council, Some will arrange for a contractor to collect and dispose of to 20 litres of hazardous waste from home, free of charge or have a tank at the local tip.
https://www.gov.uk/hazardous-waste-disposal
Share this post
Thanks.
Put it down a loo, preferably on a rainy day. The dilution with many thousands of gallons of water by the time it gets to the sewage works will render it harmless.
It will also help to disperse fat bergs.
Share this post
Hi just got back from a quiet Chester, thanks for all your suggestions Will use member 170 wet and dry system using deionised water cheers once again.
Share this post
When I had some to dispose of I rang the water company and they told me my local sewerage plant was ‘small’  (serves a town of 15000) and more than a couple of litres would kill the bacteria and not to do it.  Took it to the garage that services my car and they let me put it in their waste coolant tank.
Share this post
I hope that the 15000 don't use bleach then, it kills 99.9% of germs! Bet that there is far more than a couple of litres flushed every hour.
TD'
Share this post
An alternative to wet and dry vac, is to remove the lower skin tank coolant hose at the engine end, and feed a hose down connected to a pump mounted on the end of a battery drill. Pump the old coolant directly into containers, very effective, avoids double handling and avoids dumping everything into the bilge. Will also extract the crud accumulated in the bottom of the skin tank. Pump the header tank dry first.
Share this post
Excellent method.  This is on my list to do and wondered if something like this would suffice for the pump?
https://www.amazon.co.uk/dp/B07F9WF2WM/?coliid=I1AK3E9FZKHH4U&colid=1WRD3SIH27V20&psc=1&ref_=lv_ov_lig_dp_it
Share this post
I use same method as Cas446 easy with no mess in bilge.
Got a 12 volt pump off e-bay like above but for £10
Share this post
This seams a good idea because I have large bleed nuts on both my skin tanks that will take the pump tubes, so I’ve ordered one on eBay £12.99 with free delivery.
Share this post
That may not work, the tank might have baffle plates fitted so you may not get to bottom of the tank using the vent caps.
Can you not get to the hose as in Cass446 post?
Share this post
Yes never thought about baffles but I’ll still pump out as much as I can before dropping the hoses, thanks for reminding me.
Share this post
If you are quick you could take the bottom hose off the engine end and pull it up high and feed the smaller pump tube down the hose into the bottom of the skin tank.
Share this post
Check it can pump water. Many 12 volt oil extract pumps rely on the oil they are pumping to lubricate the pump itself and can seize if water is pumped.
Another alternative is a large Pela pump. Thesecrely on a vacuum to extract oil and water from wherever and are always useful on a boat as the suction pipe is long, small and thin so will fit in many almost inaccessible areas.
Share this post
If you do exactly like Cass446 says in post #15 with a 12v pump, drill pump or Pela you will get very little if any water going into the bilge.
My engine is a Beta 43 it has a water drain on the side of engine block plastic pipe on that into container, drain, take bottom hose off engine end plastic pipe down hose extract water, job done.
Share this post
