Mad Harold Posted July 24, 2020 Report Share Posted July 24, 2020 When cruising I do miss enjoying certain meals.I should say I only have a single burner spirit stove.Toast,I can make with a perforated steel plate with wire across the top,but I do miss Sainsburys Sticky Ribs which need to be cooked in an oven.There is no room for fitting a full size cooker,so I was wondering if there was such a thing as a hob oven. I can envisage something like a steel box perhaps the size of a biscuit tin that sits on the hob. Does anyone know if such a thing exists? Link to comment Share on other sites More sharing options...
Jon57 Posted July 24, 2020 Report Share Posted July 24, 2020 5 minutes ago, Mad Harold said: When cruising I do miss enjoying certain meals.I should say I only have a single burner spirit stove.Toast,I can make with a perforated steel plate with wire across the top,but I do miss Sainsburys Sticky Ribs which need to be cooked in an oven.There is no room for fitting a full size cooker,so I was wondering if there was such a thing as a hob oven. I can envisage something like a steel box perhaps the size of a biscuit tin that sits on the hob. Does anyone know if such a thing exists? Cobb bbq is a good bit of kit. But must be used outside. Outside stays cool so won’t burn your deck. Link to comment Share on other sites More sharing options...
Mad Harold Posted July 24, 2020 Author Report Share Posted July 24, 2020 5 minutes ago, Jon57 said: Cobb bbq is a good bit of kit. But must be used outside. Outside stays cool so won’t burn your deck. Thanks Jon,had a look but that is not what I had in mind. I imagine a square box with a door and a shelf inside that can be heated on the hob. Link to comment Share on other sites More sharing options...
Bod Posted July 24, 2020 Report Share Posted July 24, 2020 There are ovens of this type for use on the wood burner stoves were available. https://www.stoveworlduk.co.uk/oven-attachment-Ottawa-5kw-wood-burning-stove Something like this. Bod Link to comment Share on other sites More sharing options...
Tracy D'arth Posted July 24, 2020 Report Share Posted July 24, 2020 Straw oven? TD' Link to comment Share on other sites More sharing options...
Rob-M Posted July 24, 2020 Report Share Posted July 24, 2020 How about something like this https://www.amazon.co.uk/Berger-1301-Omnia-Oven/dp/B000YLJQ5U/ref=asc_df_B000YLJQ5U/?tag=googshopuk-21&linkCode=df0&hvadid=309862982580&hvpos=&hvnetw=g&hvrand=6858546921459149067&hvpone=&hvptwo=&hvqmt=&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9045625&hvtargid=pla-421692801834&psc=1 Link to comment Share on other sites More sharing options...
Alan de Enfield Posted July 24, 2020 Report Share Posted July 24, 2020 14 minutes ago, Mad Harold said: Thanks Jon,had a look but that is not what I had in mind. I imagine a square box with a door and a shelf inside that can be heated on the hob. Check out a Dutch Oven, does not look like you are expecting but can do Ribs, bake bread etc. A Dutch oven is a thick-walled cooking pot with a tight-fitting lid. Dutch ovens are usually made of seasoned cast iron; however, some Dutch ovens are instead made of cast aluminium, or ceramic. Some metal varieties are enameled rather than being seasoned, and these are sometimes called French ovens Cast Iron are better than the Aluminium ones Link to comment Share on other sites More sharing options...
Mad Harold Posted July 25, 2020 Author Report Share Posted July 25, 2020 20 hours ago, Alan de Enfield said: Check out a Dutch Oven, does not look like you are expecting but can do Ribs, bake bread etc. A Dutch oven is a thick-walled cooking pot with a tight-fitting lid. Dutch ovens are usually made of seasoned cast iron; however, some Dutch ovens are instead made of cast aluminium, or ceramic. Some metal varieties are enameled rather than being seasoned, and these are sometimes called French ovens Cast Iron are better than the Aluminium ones Thanks Alan. I think the Dutch oven will fit the bill if I insert a suitable sized wire cake rack inside to keep food from burning on the bottom of it. I need to heat ready meals,lasagne,ribs in sauce etc.to make a change from my usual boat diet of bacon sandwiches and corned beef and beans. 1 Link to comment Share on other sites More sharing options...
GRLMK38 Posted July 25, 2020 Report Share Posted July 25, 2020 20 hours ago, Alan de Enfield said: A Dutch oven is a thick-walled cooking pot with a tight-fitting lid. Not according to the Urban Dictionary .... ? 2 Link to comment Share on other sites More sharing options...
Alan de Enfield Posted July 25, 2020 Report Share Posted July 25, 2020 3 minutes ago, GRLMK38 said: Not according to the Urban Dictionary .... ? Mushy peas anyone ? Link to comment Share on other sites More sharing options...
Mike Todd Posted July 25, 2020 Report Share Posted July 25, 2020 Baby Belling - if you have elwctricity! Link to comment Share on other sites More sharing options...
Tacet Posted July 25, 2020 Report Share Posted July 25, 2020 This type of oven was reasonably common at one time. Like this In my limited experience, they were used on top of a wickless, non-pressure paraffin burner and quite capable of cooking a respectable roast dinner or a milk pudding. I imagine that using one on a Primus type burner might be trickier as maintaining a low heat can be troublesome. A spirit burner might be OK Link to comment Share on other sites More sharing options...
Clanky Posted July 25, 2020 Report Share Posted July 25, 2020 (edited) Coleman camp oven, there’s one on eBay atm. Edited July 25, 2020 by Jinna Link to comment Share on other sites More sharing options...
Tacet Posted July 25, 2020 Report Share Posted July 25, 2020 Or, for the brave, https://www.ebay.co.uk/itm/Valor-oven-unusual-bygone-Turn-a-hob-in-to-an-Oven-with-Valor-111/203001608833?hash=item2f43d6ba81:g:Bg0AAOSwmBRey86C Link to comment Share on other sites More sharing options...
ditchcrawler Posted July 25, 2020 Report Share Posted July 25, 2020 1 hour ago, Tacet said: This type of oven was reasonably common at one time. Like this In my limited experience, they were used on top of a wickless, non-pressure paraffin burner and quite capable of cooking a respectable roast dinner or a milk pudding. I imagine that using one on a Primus type burner might be trickier as maintaining a low heat can be troublesome. A spirit burner might be OK My gran cooked on one of them Link to comment Share on other sites More sharing options...
transplant Posted July 26, 2020 Report Share Posted July 26, 2020 Yeah, what you're describing sounds exactly like the Coleman camp oven @Jinna mentioned. They work but you have to control the gas to maintain temperature yourself. There's also portable propane oven/hob combos. Link to comment Share on other sites More sharing options...
