steve59
Spanners, wrenches and sockets etc.
Do narrow boats use metric, imperial or a mixture of both......Thanks Steve
Share this post
Depends on age and which motor they have. Later Japanese and Eastern engines are metric so are european engines.
Old friends BMC are imperial, mostly unified threads.
Real old motors will be Whitworth if British.
Really, anything goes !
TD'
Share this post
Depends on the age of the boat and engine.
A brand new one is probably all metric, an old one probably used to be all Imperial but has had longer for random owners to alter bits so could be a mix.
Share this post
2 minutes ago, Mad Harold said:
To be sure you need two adjustable spanners.
One imperial,and one metric.😆
And a big hammer. If the big hammer doesnt work,  then dont force it just use an even bigger hammer.
Share this post
More seriously, for Beta 43 et al, metric: I use 6,8, 2x10, 12, 2x13,14,15,2x17, 18, and some bigger ones than I have forgotten the size of.
Socket sets bits: One of the most useful fits the socket set part of a belt that grips the oil filter and makes getting the filter off easy (with a large sliding T bar).
Also 2 gas bottle spanners (left handed).
Edited by system 4-50
Share this post
1 minute ago, buccaneer66 said:
Won't a gas axe and a grinder fix everything?
Out of date now it’s plasma cutters 😀
Share this post
12 minutes ago, system 4-50 said:
Adjustable spanners? Just a couple of Stilsons...
Left and right- handed ones.
Share this post
Our base engine is the John Deere/Beta JD3. The engine is made in France but to an American design so its nuts and bolts are imperial. All the marinising parts put on by Beta are metric. The fuel tank fittings on the boat are 5/16 but those on the engine are 8mm. The gearbox is a PRM and I believe its based on an earlier imperial design. PRM say its updated over the years to be metric, but think there just might be a bit of imperial left.
and the injection pump is Stanadyne, the bolts holding that together use a Torx style head but with FIVE rather than 6 points.
Portholes etc fitted with metric bolts but the larger hull openings are (of course) BSP threads.
I have both metric and imperial spanners but  keep two adjustables next to the engine and mostly just use these.
.................Dave
Share this post
Bodgers use adjustable spanners. Proper engineers use the correct spanner as it stops the nuts getting rounded off.
Share this post
A revelation!
Share this post
Don’t forget to get a bucket of steam to clean parts in and a set of long stands and sky hooks for lifting things
Graham
Share this post
Graham
Don't forget after cleaning in that bucket of steam you'll need plenty of elbow grease for lubrication 😁
Share this post
The old ones are the best👍
Share this post
Yes and my brother actually went to the hardware store when we where still at school after Dad asked him to go get some.
Share this post
Adjustables ("shifters") are fine for bigger nuts and bolts, but for the little ones its better to use the vernier caliper, the digital ones are best.
......................Dave
Share this post
Here’s a question for you Dave:
Undoing an allen key bolt,
a 5mm Allen key is too big and 4mm key too small,
what do you do?
Share this post
what do you do?
Is it in fact an imperial one? or if its a worn metric will an imperial one be a decent fit?
Is there some crap in the hole stopping the key going in?
Get a spare 5mm key and file a gentle taper on the end and then hammer it in.
Are you sure its Allen (hexagon) and not splines? whats it on?
Share this post
Nowt wrong with the head
It is in fact imperial.  3/16”
No such thing as a 4.5mm Allen key as I found out 👍
Share this post
I reckon you could find a 4.5mm Allen key if you looked on the internet, the real bugger is my injection pump, they look like allen screws but have 5 sides instead of 6.
............Dave
Share this post
............Dave
Well I never!
Just googled it and they do exist 😃
I phoned around for one and no one had one either single or in a kit. And a local engineer place I’m sure said they don’t make them.
So I went for a kit with 3/16” and it fitted perfect.
I’m always building a list of individual tools and sockets to buy. Sometimes there’s no point buying a whole set when you’ll only need one or two sizes.
Each new job seems to introduce another tool of some sort. Even if it’s just a shorter spanner to get in somewhere or a longer one for better leverage.
As an aside:
Had to buy a new wire strimmer/crimper/cutter thing the other week. Lost the other one.
- Now that is a handy bit of kit for doing simple electrics, such as 12v wire terminals, fitting 12v sockets and the like. I’d recommend one as part of a basic tool box.
Share this post
