Lino / Vinyl flooring
44 minutes ago, blackrose said:
The only thing is that my subfloor is quite uneven so what's the best way to level it? I can't easily get the floorboards up so is a plane and belt sander the way to go?
If you laid a sheet of hardboard over the subfloor, would that work?
Well I was going to lay 12mm celotex over the subfloor as insulation and then 6mm ply, but I don't think that will level it out as it will just follow the unevenness below. Won't I have to level the subfloor first?
Edited by blackrose
8 minutes ago, blackrose said:
Well I was going to lay 12mm celotex over the subfloor as insulation and then 6mm ply, but I don't think that will level it out. Won't I have to level the subfloor first?
Oh, I see. I don't know, but I'm not sure that laying anything directly on top of celotex would be advisable. Have you got advice on this from somewhere?
On 21/06/2020 at 20:18, blackrose said:
I'm thinking replacing my carpet tiles with those woodgrain vinyl planks you can get from B&Q as my subfloor is uneven and I think they'd cope with that better than real wood. Also they wouldn't be as cold underfoot as I'd lay them over 12mm celotex and 6mm ply. But they can't be laid floating, they have to be stuck down. I have a few inspection hatches on one side of the boat so I suppose in those areas the celotex and ply could float and the vinyl planks could be stuck onto that.
Don't try vinyl planks f floor not stable,.I laid mine tight, meticulously. and they are chipping/moving. Where they were just stuck down quickly with expanson on the outside edges, they seem OK, but you will not get a perfect result; dirt gets i n to gaps, vinyl lino might be better.
Celotex is not the right material underfloor
Edited by LadyG
When our Karndean in the kitchen was laid professionally they screwed 12mm water resistant MDF in 2ft squares down then filled the joint lines on top of the original 18mm ply flooring.
Our bathroom originally had ceramic tiles so a proper screed was laid. Not without problems if you see earlier post.
Just now, ditchcrawler said:
What do you consider would be wrong with laying it under a floor like that as a sandwich
Nothing if it's the load bearing one for walking on, lots if it's the standard celotex insulation.
Celotex reckon you should lay 22mm chipboard on top of it though, so 12mm ply might be a bit springy.
The karndean wouldn't be laid directly on top of the celotex. I'd be laying 6mm ply between.
https://www.insulationsuperstore.co.uk/product/celotex-12mm-tb4012-2400mm-x-1200mm-33-sheets.html
What brand did you use? Vinyl flooring planks are used extensively on floors in loads of different situations without a problem.
Contrary to what you say the specs for the 12mm cellotex above says it is suitable for flooring applications. What makes you say it isn't?
Edited by blackrose
Can you provide a link please? I thought you'd just need thin ply to spread the weight.
This is all I can find. https://www.celotex.co.uk/assets/tb4000_product-datasheet_nov18.pdf
I could lay the Karndean directly on a (levelled out) subfloor. But I know it would be cold.
Edited by blackrose
Click the "Floors" link in that PDF.  I chose to treat it as upgrading a concrete slab floor, as I assume you don't want to rip up your entire floor and insulate beneath it!
The application datasheet https://www.celotex.co.uk/assets/concrete-slab-floor_application-datasheet_nov18.pdf
recommends at least a 65mm sand/cement screed on top of the insulation, but that sheet offers an alternative of a chipboard floor.
The chipboard must be minimum 18mm tongued and grooved flooring grade type C4 to BS 5669. Lay the chipboard with staggered joints, glued with a woodworking adhesive.
In the Celotex Blog, the article on upgrading a garage floor https://blog.celotex.co.uk/technical/garage-conversions-part-2/ says
An alternative to laying 65mm screed is a 22mm tongue and grooved floating chipboard floor.  Laid to manufacturer’s instructions this also provides a stable surface but offers a thinner floor build up which is ideal if space is a premium. [...]  Any decorative finishes such as carpet or laminated timber boards can then be laid on top of the screed or chipboard floor.
Thanks. Surely the closest floor to a boat subfloor in that datasheet is a suspended timber floor?
Anyway, I've got half a sheet of celotex so I'll lay a thin piece of ply on top and stand on it and jump up and down. If it doesn't compress I reckon it'll be fine.
There are lots of things we install on boats where we don't follow the manufacturer's advice to the letter. If we did we'd need a 3.5m combined flue and chimney length for a stove like a squirrel for example.
3 hours ago, ditchcrawler said:
What do you consider would be wrong with laying Celotex under a floor like that as a sandwich
There are floor insulations designed to go under flooring, Celotex will not stand the concussion, I think it will crumble like a digestive biscuit going through a mangle.
Edited by LadyG
Think it's where boards join where you might need to be concerned - which is why Celotex recommend staggered joins. Try jumping up and down on the edge.
Yes, but you would need to lift your subfloor and insulate underneath it then replace it, getting it all down straight and applying bridging compound to the joins.  Your new Karndean then goes above it - and Karndean specifically recommend against laying their vinyl flooring on wood and it invalidates the warranty.  Where they say you can do this using 6mm high quality ply they are expecting that laid on a solid concrete floor, not on top of Celotex.
Existing floor, Celotex, 65mm cement screed then Karndean vinyl would be perfect, but will take about three inches off your headroom and mean you need to refit the galley ...
I used commercial grade engineered wooden flooring instead.
Edited by TheBiscuits
spellink
B&Q, it is shrinkage and movement of the floor I think, it will be done again as I have some left, it could be me!
I just think Celotex will not be the best available product, I could well be wrong. I understand the idea is to get a level base with a slight "spongy" surface to absorb movement, ie a sandwich.
Edited by LadyG
Concussion? You mean compression? What's the insulation designed to go under floors?
I've stood on celotex before and its compression strength is greater than one might think, especially if there's something spreading the load above. Sir Percy's point is a fair one - it's about the edges.
Edited by blackrose
I'd be laying ply down over the celotex and then the vinyl planks on top of the ply, so I'll but up two pieces of ply and lay some vinyl over the join and jump up and down on that area.
Edited by blackrose
You could always lay 2 sheets of ply , half the thickness with the joints staggered
Rubbish!  I laid a Celotex floor covered with flooring grade chipboard with staggered and glued joints as per the above advice over an area of at least 50m2 6 years ago to cover and insulate an uneven and cracked concrete base. I did this over 6 years ago and it’s as good today as the day I laid it.
That’s a good idea. Not as good as flooring grade chipboard but at least the joints are less likely to witness through the floor covering.
That's good to know, thanks.
I just talked to a neighbour who's been a painter and decorator for about 25 years and he told me that he knows a couple of floorers who do lay Karndean directly over thin ply and celotex, so perhaps it's not such a crazy idea after all.
I think the joints will witness through. Place a couple of pieces of thin ply over some Celotex and stand on the edge. As you rock back and forth I think you’ll feel the ply edges move against each other.
