Bobbybass Posted June 20, 2020 Report Share Posted June 20, 2020 Hi. I've just fitted a new tiller top bearing. When I refit the tiller, is the whole weight of the tiller taken on the bottom cup, or do you lift the rudder slightly and tighten the tiller bolts to raise it slightly in the bottom cup ? Thanks all. Link to comment Share on other sites More sharing options...
BEngo Posted June 20, 2020 Report Share Posted June 20, 2020 Sit all the weight onto the skeg. The rudder will probably rattle badly otherwise. N Link to comment Share on other sites More sharing options...
Tony Brooks Posted June 21, 2020 Report Share Posted June 21, 2020 And not only that if you suspend the stock by clamping it at the top and you cill the boat you stand a chance of ripping the top of the fuel tank off (assuming a conventional narrowboat). Link to comment Share on other sites More sharing options...
