Sign in to follow this
Jaston10078
All DC Breakers tripping
Hi everyone... Long time reader but this is my first post.
We have a Mastervolt dc circuit breaker/distribution panel that has developed a curious habit. Recently all of the breakers have been tripping all at once without any obvious cause seemingly at random.
This is our 3rd boat and the 1st with breakers rather than fuses so perhaps I'm missing something.
I've been racking my brain..... I've recently installed a Waeco compressor coolbox as well as a Mastervolt battery monitor with double shunt. Installed new horns, a tunnel light on/off indicator lamp, I also wired a toggle switch in line to the fresh water pump. Many months ago I installed a 12v audio amplifier (draws 2 amps max) taking a feed from the water pump cables.
Any thoughts would be greatly appreciated.
Many thanks.
James
Share this post
That is a strange. My first thoughts would be there is a problem in/with the breaker panel. The odds of all your DC powered items shorting at one time is about 0.  So I would start with the panel.
Share this post
I agree but I can't see all the breakers failing at once so I have no idea how that symptom could be produced. I sounds as if the protected side/appliance side of all the breakers has been shorted to negative but how that can happen I have no idea.
Share this post
I think we need a photo of the back of the panel.
Share this post
Yes, I wonder if for some reason it has a master breaker that is tripping rather than all the individual ones.
Edited to add - maybe me but I cant see and such panels on the Mastervolt site.
Edited by Tony Brooks
Share this post
6 minutes ago, system 4-50 said:
Is there any AC on the boat?
A rogue AC DC cross connection?
Share this post
I can't see how that would trip the all DC breakers but would probably trip something on the AC side.
If its an AC RCD that's tripping and the batteries are completely shot then the loss of a mains battery charger output may make it looks as if all the DC breakers have tripped. But they would not have popped out or flicked off.
Share this post
Google turns up a few hits for 'Mastervolt Circuit Breaker' but if you follow the links to the Mastervolt site you get a message that "This page doesn't exist (anymore)".  So I'm guessing it's a discontinued product.
Share this post
I got the same on some of the hits turn out to be for other makers products.
Looks like we need to wait for front and back photos from the OP because we can't look it up.
Share this post
1 minute ago, Tony Brooks said:
I can't see how that would trip the all DC breakers...
I can't see how anything could, other than a gross wiring fault, but I can't imagine such a fault. We need pictures.
Share this post
Just now, Martin Nicholas said:
My guess would be an over voltage on the supply side - a broken battery charger perhaps?
How would that trip  the breaker on a DC circuit  where the appliances were all turned off? If 240V  AC got onto the supply to the panel then I agree circuit that has the appliances turned on may trip. I know from experience that nominally 12V DC rated PVC insulated cables seem to cope with mains voltage without excess leakage.
Share this post
Tripping everything? Without damaging anything fed by the 12V?  Unlikely in the extreme, I'd have thought.
Share this post
Hi all, thanks for your thoughts. I'm grateful for your time. The boat does have AC from the Inverter, a mastervolt Dakar combi Inverter/charger. We do use the charger with our generator but the issue doesn't occur during charging. My gut feeling is something to do with the fridge or the Inverter... But I'm no electrician. FYI the Inverter and breaker panel are original from 2003
Pictures of breaker
Edited by Jaston10078
Link didn't work
Share this post
The insulation specification for automotive wiring (say BS6862) and domestic AC wiring is identical with 'smaller' CSA's (say up to 2.5mm) both being 0.6mm thickness.
Share this post
Neither of which could trip all of the breakers unless their outputs are all connected together.
Photos please.
Share this post
Photos here to help the OP out as their link did not appear properly.
Corrected link
Edited by PeterF
Share this post
Presumably the DC system is -ve earth. What would happen if an AC neutral was connected to a DC +ve?
Share this post
It would probably pop the breaker feeding the circuit that was so connected. It wouldn’t pop them all
I've edited the link to the pictures a couple of posts up... Thanks once again 🙂
Thanks peterF
Those disconnected ‘led indicator’ cables. Do they have 12V on them?
Share this post
WotEver... I'll check and let you know
Multimeter says no... They deliver 12v to the indicators
Multimeter
Share this post
The led indicators feed from the load side of the breaker meaning each breaker with an led on the load side is active... Could this be a clue?
Share this post
A neutral should be at earth potential, the same as a negative earthed DC system, but if a single neutral was connected to a DC12V  +ve then this neutral would be at earth plus 12v DC. Would this disrupt the AC feed?
And what would 230V AC on  the 12V +ve  DC bus do to the 12V DC breakers?
I am just worried that any AC system on board has lost its earthing integrity and is earthing via the DC system.
Edited by DandV
Share this post
Re-connect then and see if the problem goes away.
Share this post
