mrsmelly Posted May 10, 2020 Author Report Share Posted May 10, 2020 8 minutes ago, OldGoat said: That's clever - must be some form of perpetual energy. Praps 1.25 Kw is more realistic (Mine is/was around that from Midland Swindlers IIRC) Link to comment Share on other sites More sharing options...
WotEver Posted May 10, 2020 Report Share Posted May 10, 2020 1 hour ago, peterboat said: A joint Tony but which one? Not necessarily. I've seen tanks crack at the bottom. Or along a seam. Link to comment Share on other sites More sharing options...
peterboat Posted May 10, 2020 Report Share Posted May 10, 2020 29 minutes ago, WotEver said: Not necessarily. I've seen tanks crack at the bottom. Or along a seam. I have had a seam spit due to PRV and expansion vessel failure but all my leaks have been joints. Old tanks bottom leaks are common in houses I have found Link to comment Share on other sites More sharing options...
WotEver Posted May 10, 2020 Report Share Posted May 10, 2020 56 minutes ago, peterboat said: Old tanks bottom leaks are common in houses I have found Yup, that's something I've seen more than once. Link to comment Share on other sites More sharing options...
mrsmelly Posted May 10, 2020 Author Report Share Posted May 10, 2020 So, it is weeping from the immersion joint when cold lol. I am going to whip it out and replace with a new rubber gasket and some of that gunge The Biscuits suggested. Its so small a weep now cos I tightened it a bit but better to seal it properly. 1 Link to comment Share on other sites More sharing options...
TheBiscuits Posted May 10, 2020 Report Share Posted May 10, 2020 1 hour ago, mrsmelly said: So, it is weeping from the immersion joint when cold lol. I am going to whip it out and replace with a new rubber gasket and some of that gunge The Biscuits suggested. Its so small a weep now cos I tightened it a bit but better to seal it properly. LS-X will seal the weeping. Just dump the pressure, wipe a bit round your leaking seal without faffing and it will be fine tomorrow for over 3-bar pressure. It needs water to start curing, so you don't even need to dry the joint first. Link to comment Share on other sites More sharing options...
mrsmelly Posted May 10, 2020 Author Report Share Posted May 10, 2020 Just now, TheBiscuits said: LS-X will seal the weeping. Just dump the pressure, wipe a bit round your leaking seal without faffing and it will be fine tomorrow for over 3-bar pressure. It needs water to start curing, so you don't even need to dry the joint first. Dont think I can get to it without removing it Dood but will have a bash in a day or two ? Link to comment Share on other sites More sharing options...
