mrsmelly Posted May 10, 2020 Report Share Posted May 10, 2020 Ok so we are all a bit bored so here is a little exercise for your brains just for a laugh, I will post the result within a couple of weeks to see whos guess was nearest!! The quandry. Right I have a twin coil cauliflower with immersion fitted. I am at present on a shore line so the immersion is only ever switched off when I am away from the boat as I leave it on all day every day. A few weeks ago i turned it off and on return noticed some water round the base of the cauliflower, not loads but it was wet. I turned immersion on and a few hours later no water and all well. I did this again when we left boat for a couple of days and wt when we returned. i turned it off nearly two months ago and on returning yesterday again water at base of unit again mainly towards the front near immersion boss. Switche don and no leaks or water evident again today. Whats the panels best guess?? Could it be a weep from the immersion that epxnda and close when hot?? Its not coming from either the engine or webasto coils. Any ideas before I get my arse in to gear with the tools?? Cauliflower is 4 years old and I can see no splits or discoloration. Link to comment Share on other sites More sharing options...
Guest Posted May 10, 2020 Report Share Posted May 10, 2020 I do love how google spell check simply cannot cope with Calorifier... Link to comment Share on other sites More sharing options...
Tracy D'arth Posted May 10, 2020 Report Share Posted May 10, 2020 Most likely the immersion itself, take the cap off and have a look. Link to comment Share on other sites More sharing options...
mrsmelly Posted May 10, 2020 Author Report Share Posted May 10, 2020 Just now, Tracy D'arth said: Most likely the immersion itself, take the cap off and have a look. Thanks, yes Ive done that hoping for a clue but its dry It would have been a nice easy cheap option. Link to comment Share on other sites More sharing options...
Tracy D'arth Posted May 10, 2020 Report Share Posted May 10, 2020 Top pipe connection? Is it running behind the insulation from there? The cylinder will be taller when hot, maybe enough to seal the connection. Link to comment Share on other sites More sharing options...
Guest Posted May 10, 2020 Report Share Posted May 10, 2020 2 minutes ago, mrsmelly said: Thanks, yes Ive done that hoping for a clue but its dry It would have been a nice easy cheap option. Is it lagged? Or bare metal? I'm thinking condensation??? Or pressure relief valve??? Link to comment Share on other sites More sharing options...
mrsmelly Posted May 10, 2020 Author Report Share Posted May 10, 2020 7 minutes ago, The Happy Nomad said: Is it lagged? Or bare metal? I'm thinking condensation??? Or pressure relief valve??? Lagged and too much for codensation, I will check the valve taa. Link to comment Share on other sites More sharing options...
system 4-50 Posted May 10, 2020 Report Share Posted May 10, 2020 What is above the cauliflower where it is wet? Link to comment Share on other sites More sharing options...
mrsmelly Posted May 10, 2020 Author Report Share Posted May 10, 2020 3 minutes ago, system 4-50 said: What is above the cauliflower where it is wet? Nothing Its realy weird. Just been for another luck and prv is dry as a bone. top of cauliflower is covered in dust and dry as a bone lol. Its realy weird. Doesnt leak at all when hot and pressurised but when leave boat with pump switched off and immersion off its wet????? Weird. Leaving immersion off at moment and will monitor every hour or so. Link to comment Share on other sites More sharing options...
TheBiscuits Posted May 10, 2020 Report Share Posted May 10, 2020 27 minutes ago, mrsmelly said: Could it be a weep from the immersion that epxnda and close when hot?? That would be my guess. Give it a thumbful of LS-X paste next time it's cold. Link to comment Share on other sites More sharing options...
system 4-50 Posted May 10, 2020 Report Share Posted May 10, 2020 So the warmth of the immer is just enough to evap the water coming from ??? Link to comment Share on other sites More sharing options...
mrsmelly Posted May 10, 2020 Author Report Share Posted May 10, 2020 1 minute ago, TheBiscuits said: That would be my guess. Give it a thumbful of LS-X paste next time it's cold. Blimey..........................will google ? Link to comment Share on other sites More sharing options...
dmr Posted May 10, 2020 Report Share Posted May 10, 2020 A slightly long shot, but it could be a permanent very slight leak but when the water and calorifier and surroundings are hot it evaporates off, but when cold it doesn't. .............Dave 2 Link to comment Share on other sites More sharing options...
TheBiscuits Posted May 10, 2020 Report Share Posted May 10, 2020 1 minute ago, mrsmelly said: Blimey..........................will google ? https://fernox.com/product/ls-x-external-leak-sealer-50ml/ " LS-X is a proven, fast acting, silicone paste which is used as an effective external leak sealer and jointing compound. Description LS-X is a proven, fast acting, silicone paste which is used as an effective external leak sealer and jointing compound. It is designed for use on hot and cold water services, including potable water. Ideal for use on compression joints and screwed fittings Never sets rock hard, joints can easily be undone Ready to use, no mixing Does not shrink or crack with age Suitable for use from below freezing point to above boiling point of water Completely safe to use with drinking water WRAS – Approved Product " Nasty stuff on your fingers, but very effective. Do read the instructions though. 1 Link to comment Share on other sites More sharing options...
system 4-50 Posted May 10, 2020 Report Share Posted May 10, 2020 and put the cap back on the tube quickly. 1 Link to comment Share on other sites More sharing options...
WotEver Posted May 10, 2020 Report Share Posted May 10, 2020 5 minutes ago, dmr said: A slightly long shot, but it could be a permanent very slight leak but when the water and calorifier and surroundings are hot it evaporates off, but when cold it doesn't. That was where my brain cells were going... but from where? Link to comment Share on other sites More sharing options...
peterboat Posted May 10, 2020 Report Share Posted May 10, 2020 31 minutes ago, WotEver said: That was where my brain cells were going... but from where? A joint Tony but which one? Link to comment Share on other sites More sharing options...
Mike Adams Posted May 10, 2020 Report Share Posted May 10, 2020 Horizonall or Vertical?Stainless or Copper? I have had a similar problem where a very small stress crack developed hidden of course by the insulation. Link to comment Share on other sites More sharing options...
mrsmelly Posted May 10, 2020 Author Report Share Posted May 10, 2020 4 minutes ago, peterboat said: A joint Tony but which one? Yeah So I am starting the process of elimination. the good pojts are that I know its neither the inny or outy of the webasto or engine coils as I ahve suffered zero coolant loss over the time this has been happening. Its weird though as it leaks when cold and not under pressure rather than when pressurised. 2 minutes ago, Mike Adams said: Horizonall or Vertical?Stainless or Copper? I have had a similar problem where a very small stress crack developed hidden of course by the insulation. Its vertical copper thanks. Its going tobe a slooooow proces of elimination over the course of a few days methinks. Link to comment Share on other sites More sharing options...
OldGoat Posted May 10, 2020 Report Share Posted May 10, 2020 Tim, you're writing about the "bottom" - do I infer from that comment that the heater is at the bottom of the unit (mine is and it's a pain to remove 'cos I ghave to drain and remove - thus I haven't). If it is the onlky sensible suggestion is that when the unit is on the water at the bottom of the tank plus the heater is warm - p'raps sufficuently warm to cause expansion - abd that stops the leak.. or mebe not.... Link to comment Share on other sites More sharing options...
mrsmelly Posted May 10, 2020 Author Report Share Posted May 10, 2020 1 minute ago, OldGoat said: Tim, you're writing about the "bottom" - do I infer from that comment that the heater is at the bottom of the unit (mine is and it's a pain to remove 'cos I ghave to drain and remove - thus I haven't). If it is the onlky sensible suggestion is that when the unit is on the water at the bottom of the tank plus the heater is warm - p'raps sufficuently warm to cause expansion - abd that stops the leak.. or mebe not.... Yow Dood, that is precisely my thoughts but?????? Yes its in the tank bottom Plus points are that I am belt and braces when I fit stuff so I have plenty of isolation valves and indeed I fitted a drain tap at the lowest point so I can drain it off if I have to. Link to comment Share on other sites More sharing options...
Tacet Posted May 10, 2020 Report Share Posted May 10, 2020 53 minutes ago, system 4-50 said: So the warmth of the immer is just enough to evap the water coming from ??? That's my guess too. There may be some chalky, dusty residue at the leak. 1 Link to comment Share on other sites More sharing options...
OldGoat Posted May 10, 2020 Report Share Posted May 10, 2020 2 minutes ago, mrsmelly said: Yow Dood, that is precisely my thoughts but?????? Yes its in the tank bottom Plus points are that I am belt and braces when I fit stuff so I have plenty of isolation valves and indeed I fitted a drain tap at the lowest point so I can drain it off if I have to. Oh - good guess then! (Just as well 'cos a bollocking from your goodself is something to be avoided.. IIRC it's a small boss variety, tus easier to undo when the tank is empty. However it's only a 1KW variety and when working it took weeks to heat up - so I haven't bothered. An hour or so with the 'splutter on is so much easier. 1 Link to comment Share on other sites More sharing options...
mrsmelly Posted May 10, 2020 Author Report Share Posted May 10, 2020 3 minutes ago, OldGoat said: Oh - good guess then! (Just as well 'cos a bollocking from your goodself is something to be avoided.. IIRC it's a small boss variety, tus easier to undo when the tank is empty. However it's only a 1KW variety and when working it took weeks to heat up - so I haven't bothered. An hour or so with the 'splutter on is so much easier. Lol. Its a full size fitting but only 1.25 watts however heats up in about 4 hours plus. I am plugged in at moment so immesrion is cheap and keeps us in constant water for what we use ? Link to comment Share on other sites More sharing options...
OldGoat Posted May 10, 2020 Report Share Posted May 10, 2020 52 minutes ago, mrsmelly said: Lol. Its a full size fitting but only 1.25 watts however heats up in about 4 hours plus. I am plugged in at moment so immesrion is cheap and keeps us in constant water for what we use ? That's clever - must be some form of perpetual energy. Praps 1.25 Kw is more realistic (Mine is/was around that from Midland Swindlers IIRC) Link to comment Share on other sites More sharing options...
