Hi All
I've got some Toplac Donegal Green that was for use on my boat roof, but as I've not idea how long it'll be before I get back to it and my garage door needs attention I thought I could make better use of my time using the Toplac on this - overkill I know but maybe good practice for me!  I've read the instructions but I couldn't see how long it takes to dry (only the many ways it can kill you!)?  Can anyone hazard a guess?
Also, thinking ahead to when I can start to paint the boat roof, it has some areas of grip (sand in the paint?) - i'm not fussed keeping these but is it possible to just paint over these patches if they don't have any rust patches etc?
Share this post
Yes, on a hot day might even be touch dry in 2 hours. 24 hours before putting a second coat on, but even then it might be a bit difficult if you wanted to sand it first. It then takes maybe a week for the paint to get fully hard.
I am a crap painter but I do like Toplac as its quite forgiving of my poor painting skills, but I am starting to appreciate Craftmaster a bit more of late, especially their high build undercoat which hides all sorts of poor prep.
...................Dave.
Share this post
Even the sanded areas will need keying before painting over, otherwise you will get it flaking off very quickly. Use a wire brush or similar.
Share this post
I'm pleased you said that.  I have seen so many sanded roofs flake new paint within a year that I ran a wire cup brush and a wire wheel all over my roof before repainting, fast enough to scrub it but not hard enough to strip it bare.
How long it will last I don't know, but so far so good.
Share this post
Thanks. Got a sanded roof (ie non slip roof) to do this summer and was wondering same.
Edited by mark99
Share this post
Now thinking about getting this done... obviously temps are falling etc so wondering if i've missed my opportunity this year?  Calcutt boats have a covered wet dock so maybe this is the thing to use but still not sure on temps as this isn't heated etc...?
Share this post
Depends on the dew point temperature. Most weather apps show dew point for each 24 hour period.
Usually at this time of the year the night time temperature drops below this. However the current weather is keeping it (just) above this, which tempted me into putting a coat of varnish on my cratch board and rear doors. Luckily I got away with it.
Share this post
On 12/04/2020 at 17:06, robtheplod said:
Hi All
Are you proposing to take the garage door to Calcutt boats ?
Share this post
Without heat, you're running into the back end of painting season. The weather we're having is great, but without cloud after, the heat dissipates over night and dew will begin to be a problem. The sun is warm still, but weaker. A draft will give rise to blooming.
Share this post
Must be a widebeam - there's not enough room for a garage on a narrowboat.
Share this post
1 minute ago, robtheplod said:
doesn't everyone have a garage door?  :)
Well .............. yes.
But we don't make a big fuss about it and take 5 months thinking about painting it.
Super Yacht Garage … #yachtsforsalepictures | Luxury yachts, Boats luxury,  Boat
  • Happy 2
  • Haha 2
Share this post
Thanks, so looking on an app Dew point is 11oc at Napton, so I'm guessing so long as the temperature doesn't fall below this then from a painting perspective I'm ok?  sorry if this seems obvious!!
Share this post
I was trying to paint last October, each morning I'd 'mop the decks' to get the overnight dew off, towel them dry and go and have a cup of tea whilst they finally 'dried off'
Went back and the decks were as wet again, dried off again and started painting - the brush started just sliding in the moisture as the dew was forming as fast as I could dry it off.
Just gave it up as a bad job and planned to start this Spring, C19 put paid to that idea as we couldn't get to the boat until mid July when the travel restrictions were lifted.
Share this post
Yup, however i prefer to have a couple of degrees leeway, just in case the weather forecasters get it wrong, heaven forbid.
Share this post
Calcutt boats have 3 wet docks.
Share this post
The temperature of the steel surface must be above the dew point otherwise dew will form.  So you can’t start painting until the boat itself is a few degrees above the dew point.  In the morning the boat may be colder than the dew point, so you must wait until the boat is warm.
Edited by Chewbacka
Share this post
Constantly amazed how much water can form on  steel overnight (not undercover) at this time of year and we live in  the tropics near to the equator (Surrey). OCT is the end and Sept you have to be an intelligent interpreter to choose your short painting window especially if your boat is in the frozen wastelands and tundra (north of Islington).
Edited by mark99
Share this post
Painting!  Don’t talk to me about painting! Hot day today so perfect to get two coats on the decking outside the back door before the weather breaks. Cleared the decking, brushed in some cleaning solution. Got out the pressure washer... I’d get more pressure blowing down the blasted hose!  I’m not taking it to bits again, I’ve already repaired it once this year... no-one stocking a decent one local to me so I’ve ended up ordering one on Prime delivery from Amazon. I’m now hoping it arrives early so that I can get at least one coat of stain on the decking as soon as it’s dry. Gonna rain on Wednesday...
Just when I finally got my round tuit.
Share this post
Tommorow is the last outdoor painting day of the year....after 10am......depending on local fog clearance....(South of Manchester)......and not after 3pm .
Share this post
Yup. I’m hoping the pressure washer arrives early...
Share this post
That explains a slight bloom I got on some work I did a year or so ago. It was undercover but next to a door and I left the door open. Kneeling doing the work I recall a cold breeze. Next day, came back door still open and the bloom was there. Luckily it's not a terrible bloom, but it's there!
Share this post
It must be tricky for those who paint under flyovers; they always seem like wind tunnels.
Edited by Higgs
Share this post
