SusieC Posted March 23, 2020 Report Share Posted March 23, 2020 Has anyone tried the Star Brite rust converter? https://www.chmarine.com/starbrite-rust-eater-and-converter-650ml/ Don't see it mentioned in any posts when I searched.... Anyone had success with other brands? Link to comment Share on other sites More sharing options...
Slim Posted March 23, 2020 Report Share Posted March 23, 2020 Why try an unknown. Masses of people speak highly of both Vactan and Fertan. I've got both! Just bought 1l of Vactan for about £19 delivered 1 Link to comment Share on other sites More sharing options...
Troyboy Posted March 23, 2020 Report Share Posted March 23, 2020 Another recommendation for Vactan from me. Link to comment Share on other sites More sharing options...
WotEver Posted March 23, 2020 Report Share Posted March 23, 2020 37 minutes ago, Troyboy said: Another recommendation for Vactan from me. Me too. I like ‘that crap’ Link to comment Share on other sites More sharing options...
Richard10002 Posted March 23, 2020 Report Share Posted March 23, 2020 Vactan used to great effect in my very rusty engine hole a couple of years ago. All good so far, and it's not the dryest of spaces. Link to comment Share on other sites More sharing options...
ditchcrawler Posted March 23, 2020 Report Share Posted March 23, 2020 So we should never try new products, what happens if the makers of Vactan go out of business Link to comment Share on other sites More sharing options...
WotEver Posted March 23, 2020 Report Share Posted March 23, 2020 6 minutes ago, ditchcrawler said: So we should never try new products, what happens if the makers of Vactan go out of business We’d have to try new products Link to comment Share on other sites More sharing options...
Richard10002 Posted March 23, 2020 Report Share Posted March 23, 2020 29 minutes ago, ditchcrawler said: So we should never try new products, what happens if the makers of Vactan go out of business I'd probably give Fertan a go if someone else didn't take advantage of the gap in the market for Vactan, by another name. Link to comment Share on other sites More sharing options...
Tony Brooks Posted March 23, 2020 Report Share Posted March 23, 2020 53 minutes ago, Richard10002 said: I'd probably give Fertan a go if someone else didn't take advantage of the gap in the market for Vactan, by another name. I think they do. Look in car shops at the DIY rust neutralisers. I think Kurust is so similar to Vactan it may come out of the same drum but its available in smaller packages. 1 Link to comment Share on other sites More sharing options...
MtB Posted March 23, 2020 Report Share Posted March 23, 2020 1 hour ago, Richard10002 said: I'd probably give Fertan a go if someone else didn't take advantage of the gap in the market for Vactan, by another name. Fertan is very, very different. Link to comment Share on other sites More sharing options...
SusieC Posted March 23, 2020 Author Report Share Posted March 23, 2020 What’s the difference between Vactan and Fertan I will be using it for external spots on the topisides around windows Link to comment Share on other sites More sharing options...
Richard10002 Posted March 23, 2020 Report Share Posted March 23, 2020 1 hour ago, Mike the Boilerman said: Fertan is very, very different. Yes.... 1 hour ago, SusieC said: What’s the difference between Vactan and Fertan I will be using it for external spots on the topisides around windows You allow Vactan to dry, and it can be used as a primer. Fertan has to be washed off, then the water dried off, before applying any paint coatings. Sounds like a right faff! There may be other differences, but IIRC the above difference was what made me plump for Vactan. Link to comment Share on other sites More sharing options...
MtB Posted March 23, 2020 Report Share Posted March 23, 2020 17 minutes ago, Richard10002 said: Fertan has to be washed off, then the water dried off, before applying any paint coatings. Sounds like a right faff! Its worse than that, you have to get the timing right too IIRC. Wash it off after no less than 24 hrs and no more than 48, or something like that. Link to comment Share on other sites More sharing options...
matty40s Posted March 23, 2020 Report Share Posted March 23, 2020 Bkackrose will be along in a minute..... 1 Link to comment Share on other sites More sharing options...
nbfiresprite Posted March 24, 2020 Report Share Posted March 24, 2020 I use CORTANIN F Anti Rust Treatment which is Polish, Works just like Vactan, Not a bad price either https://www.ebay.co.uk/itm/CORTANIN-F-Anti-Rust-STOP-CORROSION-Treatment-Converter-Protects-Car-Metal-250mL-/202028447392?hash=item2f09d576a0 Link to comment Share on other sites More sharing options...
Tracy D'arth Posted March 24, 2020 Report Share Posted March 24, 2020 (edited) Couldn't get a shine with that polish. Its expensive, Vactan is cheaper, around £15 a litre delivered if you shop around. Will we still get stuff delivered? "I've found the bitch and just locked it in my coal shed with food and water, I intend getting a good night's sleep, nighty nite!" Edited March 24, 2020 by Tracy D'arth added more Link to comment Share on other sites More sharing options...
Dr Bob Posted March 24, 2020 Report Share Posted March 24, 2020 10 hours ago, Mike the Boilerman said: Its worse than that, you have to get the timing right too IIRC. Wash it off after no less than 24 hrs and no more than 48, or something like that. Vactan is a rust converter and primer in one. Fertan is a rust converter. The advantage of Vactan is you dont have the extra day to wash off the fertan but the disadvantage is that it is then a 'compromise' as the stuff is doing two jobs. The compromise is that the Vactan is more viscous (as it has to act as a primer coating) so it is not the best at wetting out the rust. Fertan is thinner and wets out the rust better so will theoretically stabilise it better. What is certain is that if you can accept the extra days work washing and drying then you can put a better primer on once the Fertan has done its job. Which is better. Dunno! I have only ever used fertan and thinks it works as well as can be expected as long as you make sure its dry before priming which is not always easy at the bottom of engine 'oles or gas lockers. Link to comment Share on other sites More sharing options...
MtB Posted March 24, 2020 Report Share Posted March 24, 2020 14 hours ago, matty40s said: Bkackrose will be along in a minute..... I can see him galloping over the hill now, on his hobby horse.... Link to comment Share on other sites More sharing options...
WotEver Posted March 24, 2020 Report Share Posted March 24, 2020 10 minutes ago, Mike the Boilerman said: I can see him galloping over the hill now, on his hobby horse.... Here he comes, over the hill... Far away but getting slowly closer... Just a dot but getting bigger... He’s coming now... Closer still... He waves... I wave back... Getting closer now... oh... ... it’s not him. Link to comment Share on other sites More sharing options...
matty40s Posted March 24, 2020 Report Share Posted March 24, 2020 1 hour ago, Mike the Boilerman said: I can see him galloping over the hill now, on his hobby horse.... Thor Heyerdahl told Blackrose that Vactan was absolutely useless on Kon Tiki.... 1 Link to comment Share on other sites More sharing options...
cuthound Posted March 25, 2020 Report Share Posted March 25, 2020 17 hours ago, matty40s said: Thor Heyerdahl told Blackrose that Vactan was absolutely useless on Kon Tiki.... I heard he also said that Fertan was useless on Ra... ? Link to comment Share on other sites More sharing options...
