DandV
This afternoon 2024
Top lock 16 Marston Doles. Local boater said the not-yellow bag had only been there this year so anr repair wasn't likely any time soon ...
junction with the Engine Arm at Marston Doles Compare 18Mar2006
isolated canal and its boat hereabouts. Wonder how long before it needs its bottom blacking ?  Compare   17May2015  24May2015  4Apr2018  22Jun2018
2 hours ago, PeterScott said:
This afternoon 2024
Is the blue bag to repair a broken yellow bag?  :) :)
This evening
spacer.pngClaydon SOxford
Replacement 'beam' was planks on either side of the original sawn-off and shortened beam, separated by cross-pieces and studs and nuts to hold to the original beam, and at a higher angle to it. Fuel for the discussion whether these are primarily balance beams or operating levers. The end of the original and its handle is on the ground.
"No overnight mooring in flight"... but doesn't tell us why not - eg whether the flight is more leaky than others hereabouts, and the intervening pounds are long-ish ...
... with plenty of piling rings (for lunchtime moorers, obviously)
Edited by PeterScott
extra pic
Thus morning 2024
Napton Junction  (Wigrams Turn)
Compare  24Mar1971/31Mar2005  10Jun1988   8June1990  29Jul1994  27Oct1994  16Aug2005  22Sep2005  29Jan2006  17Mar2006  3Nov2006  1Feb2007   9Nov2008   5Feb2009   22Jun2018  ##2019  25Oct2020
This morning 2024
Every canal scene is brightened up with a splash of yellow ...
Graffiti says "FOR 4½ YEARS " and "Can't Run a Tap" ... The bag looks too clean for having had an extended stay ... but maybe it's a volunteer's job to wash it occasionally. Should keep them out of mischief ...
Broadmoor Lock No 24 Southern Oxford
and an unexpected visitor ...
This evening 2024
Aynho Weir Lock No 33 (SOxford) has a river level indicator above the lock to warn ascending boats of hazardous river levels, while descending boats entering the river section are promised an indicator board under bridge 187, just below Nell Bridge Lock No 32 ...
Sadly there is no sign of an indicator board under the bridge ...
Compare  20Sep2005   19Mar2006  1Oct2006  5Apr2018 21Jun2018  16Aug2021  27Dec2021
Grant's Lock No 30  SOxford  with a sad-looking lock house also has a non-operational offside top paddle (no rack, nothing to wind), which doesn't even qualify for a yellow bag ...
This morning 2024
spacer.pngDukes Cut lock closed.
Sadly the CRT stoppage notice only knows of the slowly working paddle in the Top gate paddle housing not functioning correctly due to the unidentified defect, and nothing about the padlock _sigh_
Wolvercote Junction SOxford Main Line/Dukes Cut
Compare  20Mar2006   3Oct2006 (#2)
extra pic
This afternoon 2024
Isis Lock Oxford, SOxfordC,
The National Rivers Authority was abolished in 1996 ...
Compare 14Feb1988  28Feb2014 20May2015 24Feb2020 (#227Feb2022  7Feb2024
Hythe Bridge Arm (Oxford)  Compare  25Feb2001  17Sep2005 (#2) 28Feb2014  23May2015   24Feb2020  27Feb2022  7Feb2024
Jerico Wharf  Oxford    A project with lots of plans but no discernable action for the last 32 years  since the boatyard closed...
Compare  20Mar2006  27Feb2022
Railway Swing Bridge
tracks are no longer part of an operational railway...
Compare  14Feb1988  6Jun1990 25Feb2001
Sheepwash Channel Footbridge   -   Junction with River Thames navigation channel  Compare 14Feb1988
This damp Sunday morning 2024
Shipton Bridge No 220 - gate
Enslow Railway Bridge No 215A   OxfordC
an ordinary railway bridge alongside the River Cherwell ...
with a Closure Mark ... As You Do
and hereabouts summer is sadly ending
This afternoon 2024
Horse Bridge Junction S Oxford and a boat moored in the canal section  Compare  4Jun1990 13Apr1996 19Mar2006
By Allen's Lock No 36 OxfordC
Somerton Deep Lock   Southern Oxford
Compare  5Jul1971  13Apr1996  8Feb2004   20Sep2006   4Oct2006  23May2015  20Jun2018  18Sep2024
extra pic
Last Friday 20Sep2024
Roundhouse Thames and Severn Junction with  River Thames  Compare 18Sep2005
and a recent sign on the bridge, not particularly helpful for narrowboats which are too long to turn downstream of the bridge ...
Lechlade: it was too rainy to hire one ...
... of either sort
and supervising proceedings at St Johns Lock Upper Thames
Compare  10Sep1980 18Sep2005  20May2015
This morning 2024
South of br183 Southern Oxford. Less fun to start the day in the rain ...
... and it did ease off for a bit ...
and a flow of water running around Kings Sutton lock
extra pic
This extremely wet afternoon 2024
CastleQuay Banbury and Banbury Lock  SOxford    Compare 6Jun1990  17Feb2023
spacer.pngFrom t'other direction ...
Banbury has a complicated relationship with its busstation: its first required the canal basin to be filled-in; and it moved to its current position to make way for a shopping centre.  Today's rain made a bid to reclaim it for the waterways. This bus did eventually leave with passengers aboard ... The waterspout was probably just too much rainwater for the sewerage system to cope ...
