mattsbsmith
Grand Union Paddington Arm Headroom
On 18/03/2020 at 19:21, Captain Pegg said:
If you published the width as per your yellow outline and the height of your red outline as the single limiting dimensions it would include craft that don’t fit. Those dimensions are legally binding on CRT.
Where do you get the idea of dimensions of that nature being legally binding?
Share this post
I think "statutory" means "enacted by statute"
These are the statutory dimensions for each canal, when it was decided to reclassify to :
Commercial Canal
Cruising Canal (Leisure)
Remainder Canal ( don't do much to it - leave it to go derelict)
Edited by Alan de Enfield
Share this post
Indeed Alan, and as operators of largish commercial craft we've had cause from probably the 70s on to quote Fraenkel in arguments with BWB. I was merely querying Captain Pegg that a measurement to the top of the arch and the overall width would be legally binding. The bit of Fraenkel you give is actually talking of the maximum craft dimension rather than dimensons of any structures - not quite the same.
Tam
Share this post
Indeed it is not infrastructure sizes, but maximum boat size.
The legislation states that the infrastructure should be maintained such that a boat of that size can still pass - which was recently highlighted where a repaired lock on the (I think) K&A meant a boat could no longer pass.
It is interesting to note the comment in the 'notes' for the Ashby canal.
I read it as :
"A high narrowboat may be able to pass, but a high widebeam may not"
Share this post
I read it as :
I’d like to see a widebeam turning onto the Ashby from the Coventry...
Share this post
Tam
I never referred to the measurement to the top of an arch, particularly as I doubt that’s what any published CRT dimensions use as a point of measurement. My reference was intended to be to the obligation on CRT to maintain waterways fit for passage of craft that fit within a set of dimensions for the waterway in question.
JP
Edited by Captain Pegg
Share this post
If they can get those big barges under the lowest bridge on the Canal di Midi without any damage you should be fine on a 13ft widebeam on the GU Paddington arm.
This was me taking my 12ft widebeam through the bridge at Bidford on Avon. Slowly does it...
Edited by blackrose
Share this post
The oil tanker barges on the South Yorkshire Navigation have a hydraulic lifting mechanism to lower the bridge so it can pass under low bridges. Not a good photo, but here is an old one from 2012 with the bridge raised again at Aldwarke lock in Rotherham after it had been lowered to pass under the 1820's arched bridge behind it.
Jen
Share this post
