StephenA
Boat Safety and Coronavirus
5 minutes ago, Mike the Boilerman said:
But an "All hose" system is not the same thing as a rigid system with final connection to fixed appliances with a flexible hose.
But that was not the question, David asked :
36 minutes ago, David Mack said:
Does the BSS allow flexible hoses for connections to fixed built in appliances? I thought they are only to be used for portable appliances (which also require a chain or similar to prevent the hose taking any load).
The answer is yes, and you can use hose from gas cylinder to appliance.
Share this post
Now you're just being awkward. You know perfectly well what he meant.
Share this post
As I am sure you were just being awkward when you replied in a post to @Jennifer McM
Oh dear, another one who can't tell the difference between a figure going down, and the the rate of increase in that figure going down.
Pot / Kettle ?
Share this post
Pot / Kettle ?
Not really. Its another of my hobby horses.
Person A: I see inflation has fallen for the third month in a row.
Person B: It can't have done, the cost of my weekly Tesco shopping is still going up.
Share this post
1 hour ago, Mike the Boilerman said:
I think the BSS is silent on the point.
I agree with Mike.  Nowhere does it stop you making the final connection to (say) an inbuilt hob in a flexible pipe, provided there is an isolation valve where it joins the rigid pipework.
Our last boat had such an arrangement, and three different examiners never made any adverse comment about it.
Share this post
Re Literal interpretation:  When last I looked (several years ago) the maximum length of an appliance gas hose (the one with the twist connector) allowed was 3 ft.  Now they are supplied as standard at 1M.  A literal test would fail, commonsense ones do (did) not.  Similarly the rule about a red stripe IIRC.
Share this post
The BSS was updated to 1 metre several years ago.
It was 1 metre in the 2013 issue of the BSS
Edited by Alan de Enfield
Share this post
I'm surprised it was that long ago. It caused me a problem at the time, having 3 of them!  But the example still stands.
Share this post
Is there any update on the current situation for boats that are due a BSS? I have a couple of months before mine is due, but have had a reminder from CRT.
Share this post
Currently suspended until the 14th April. I spoke to my examiner a few days ago and he thinks there will be a six month extension but not sure from what date.
Share this post
Seems reasonable, given they have done the same for MOTs.
Share this post
I have the same date mid April date from my surveyor, who was advised to hold on any further BSS surveys  a few days before he was due to do ours.
I am not in any rush as we are not going anywhere and not even visiting the boat despite it being close to home.
MOt test on cars have been extended. so it would make sense to do similar for BSS as there will be a backlog  building up followed by  a mad rush when we can all get back to boating. I would have thought extending BSS certs by a year would be a wise move.
It's not like there are a surplus of  surveyors anyway .
Share this post
Latest CRT email says now extended until 30th April. Just thinking it should be longer or phased in some way as all the overdue surveys can’t be done on one day.
Share this post
https://canalrivertrust.org.uk/enjoy-the-waterways/safety-on-our-waterways/coronavirus/coronavirus-and-boating-faqs
"With Government today (16 April 2020) extending the Coronavirus lockdown period to 9 May 2020, the Canal & River Trust is accordingly extending the suspension of the normal requirement for boats to move every 14 days to 9 May.  During this period, boaters do not need to contact us to tell us they will be staying in one location for more than 14 days."
"Following the Prime Minister’s announcement on 23 March 2020 regarding the UK’s response to the coronavirus crisis, the joint owners of the Boat Safety Scheme (BSS) allowed a temporary extension to safety certificates for those craft requiring an examination before 14 April 2020. This date is now extended until the end of the month, 11 May 2020."
So canals re-open on Sat 9th. Certs must all be done by COB on Monday 11th.
Share this post
At last, towards the end of last week, a chap from the BSS rang me back. He talked a lot of sense, the gist of which was, don't worry, we are being sensible about the situation. He told me that, while restrictions remain in force, the lack of a BSC would not prevent us getting a new licence or renewing our insurance. I feel most reassured now.
Share this post
What needs to be sorted is how long there will be for renewing once restrictions are lifted. Not everyone will be able to renew on day 1 as there will be loads that have lapsed during the closedown I expect.  Not knowing when restrictions will be lifted means you can't book an examiner in preparation either.
Our examiner reckoned there would be 6 months grace period but I've not seen anything to say that officially.
Share this post
Sort of on topic.
I was advised that if I were to upgrade my propane gas regulator it ought to be of higher load as I have heating, cooker and hob all gas.
How do you choose a better propane gas regulator ?
Thank you!
Share this post
When you look at the specs for a regulator they will tell you how much gas it is designed to pass per hour or minute.  If your current set up works OK, look up your existing regulator, and its flow rate, then get one that has a bigger flow rate.
Otherwise you need to work out the flat out gas consumption of each appliance, from the manual or the rating plate, then add them all up and get a regulator that passes more gas than that.
Alternatively, ask the competent person who you are  going to use to fit the new regulator to provide one that is the right size.
N
Share this post
BSS exam completed yesterday and certificate issued today. Pass with no comments , which is always a relief. Already registered and recognised on the C&RT website.
So just letting people know  the BSS are permitting action by the surveyors
 I did not attend for the examination and in fact have never been present for a BSS exam despite having 4 previously. We had to agree to keep away from the boat  two days before the exam and stay away  two days after as an anti-Covid precaution...which is not a problem.
Just need to consult with my financial expert  to pay for it😁
Share this post
Being a boat safety examiner myself I am still waiting for the go-ahead to restart the examination process.
The BSS office as of 1.30pm today (Tuesday) could not tell me when we could restart.
So I wonder who this examiner would be when he wasn't supposed to be doing them.
I suppose the post could be fake news.
Share this post
As I take it you are self employed and the BS have not furlond you how can they stop you doing examinations
Share this post
We had a suspension email on 27th March, suspending all examinations till further notice.
Share this post
It certainly isn't fake news.
As proof check my boat on the BSS system to which you presumably have access .........White Angel  , Index 109615  date of BSS expiry 11th May  2024 ....and report back.
Share this post
MartynG, can you give me a ring please.
Edited by Athy
Share this post
