Eldog Posted February 21, 2020 Report Share Posted February 21, 2020 Hi Grateful for opinion/advice. Just lit Thetford cooker after long winter break and flame has an odd burn pattern with a couple of bright yellow flames. Does anyone know cause/cure and indedd if it's safe to use. Thanks Link to comment Share on other sites More sharing options...
mrsmelly Posted February 21, 2020 Report Share Posted February 21, 2020 Likely a bit of muck in the burner holes or jet. Go to pound land or get a tin of air duster from fleabay and give it a good blast. Worked perfectly for me at a pound. Link to comment Share on other sites More sharing options...
Eldog Posted February 21, 2020 Author Report Share Posted February 21, 2020 Bloomin heck - that was quick - Thanks Link to comment Share on other sites More sharing options...
WotEver Posted February 21, 2020 Report Share Posted February 21, 2020 You might find that burner simply lifts off, in which case do so, then give it a good shake (outside) and maybe a gentle rub with a wire brush. Link to comment Share on other sites More sharing options...
BEngo Posted February 21, 2020 Report Share Posted February 21, 2020 That looks OK in the short term. There are no yellow flames (which would indicate a shortage of air in and too much CO out and would not be a Good Thing) The coloured flames are orangey which is probably rust in the burner after a winter unused. As said give it a good clean with a wire brush, air duster and vacuum cleaner. N Link to comment Share on other sites More sharing options...
