Sign in to follow this
eid
Filling a hole.
I have a solar contraption on the boat roof which needs to be removed. I expect the bolt holes go right through the steel.
What is the best way to fill the holes left?
Thanks.
Share this post
When I took the radio aeriel out I filled it with a bit of fibreglass, using a kit from Halfords. Twenty years later, it hasn't leaked yet. Once it's hardened, you can sand it down flat to the roof... though I admit I didn't bother.
Share this post
For bolt holes any exterior grade filler should be fine, and once sanded down and repainted there should be nothing to show there had been holes.
But if you have removed a chimney flue or mushroom vent you probably need the services of a welder.
Share this post
If you use fiber glass paste type fillers and rub it down flat to the roof in time it will fall out and leak
if it was me I would use dome headed bolts with a good type if sealer under the head
Graham
Share this post
Tap the hole....put a bolt in with some thread lock....grind it flush and repaint...you can always skim with some filler if needed
Share this post
32 minutes ago, Mike the Boilerman said:
What IS this solar contraption that needs removing?
Good question.
Share this post
16 minutes ago, Murflynn said:
and how do you ensure it won't fall out one day?
I can't. But I can think of a couple that have done over 15 years.
Share this post
1 hour ago, Iain_S said:
I use epoxy putty.
When my boat started sinking and we could see the hole in the baseplate, we shoved some marine epoxy into the hole, dropped a rubber pad on it and a weight on that. Plug's still there. When they shot blasted the hull before replating, they blew a hole in the side of the boat below the waterline, that had been patched with fibreglass. Must have been there over 30 years, because I certainly didn't do it!
  • Horror 1
Share this post
blimey - remind me not to go aboard your colander.
Share this post
On the Norfolk Broads once, one crew member's stupid action caused us to punch a foot-diameter hole in the bottom of our hired wooden sailing boat. We grabbed hold of him and shoved his backside into the hole; it was just about watertight enough that we managed to sail to the nearest boatyard (which took 20 minutes) where they hurriedly put straps under the boat and lifted it up. By the time we had finished lunch in the nearby pub they had nailed a sheet of plywood over the hole; it stayed in place and waterproof for the rest of our fortnight's holiday.
Share this post
Thanks all, that's given me some ideas to think about. I was considering liquid metal but I notice no one has mentioned it?
I think I'm leaning towards the domed bolt with some kind of sealant, although it would be nice to make it flat again. Its probably going to be under the new solar panels anyway though.
It's a mount for solar panels which allows each panel to be tilted at about 45* or otherwise lay flat on the roof slope. It was made by the last owner from a Homebase (or similar) trolley I believe. It does a great job but I need bigger panels.
If anyone wants it and can collect it'll be going in the spring (probably along with the panels).
Edited by eid
Share this post
Depending on how big the holes are you could you cladding fixings as they have a built in sealing washer.
Share this post
I'm sure someone will love that!
Your could give it to them on condition they weld over the holes!!
Share this post
That would certainly make things simple. They even come with colour matched caps!
https://www.steelroofsheets.co.uk/categories/cover-caps/
Welding would be a nice solution actually but I was told never to do it while the boat is in water.
Perhaps I could get it done at the next blacking.
Share this post
Somehow I missed this on first read. This sounds like a great solution. The holes may already be tapped anyway.
Edited by eid
Share this post
This method will work even better if a fine thread is tapped, you can also put the bolt halfway in and saw the excess off leaving less work for the grinder. A thread sealing compound such as nutlock may also be useful.
Share this post
Thanks I'll look into that.
Is this the stuff?
Edited by eid
Share this post
It may be a problem if you were to try doing this with a bolt that was underwater but it wont be an issue on the roof!
Share this post
Or if you have access, screw the bolt in from the inside until it is tight and grind off the projecting thread on the outside.
Share this post
