Sign in to follow this
Bob692
Wheel Barrow wheels, pneumatic or puncture proof?
Are the puncture proof wheels too solid to make a good fender? Or are they the ones to get?
Share this post
15 minutes ago, Iain_S said:
Not sure if they'd float.
Me neither.
Share this post
Are you wanting a replacement for conventional hanging down fender or do you want a wheel that floats flat on the surface to keep your boat a little way out from the canal wash wall?
.............Dave
Share this post
10 minutes ago, WotEver said:
Me neither.
I reckon you would but, if you're unsure, think about lighter footware...
Share this post
I’ve used wheelbarrow wheels for over 20 years to counteract the Shroppie shelf, and never had a puncture, so I would think the ordinary 8” wheels off eBay would be fine.
Share this post
Yes, I wanted them for the shroppie shelf and other places where it's difficult to get right along side.
Thanks, that's perfect.
Share this post
There are a few places where they are not quite wide enough, but they do for most of it.  I have them on lines with handrail hooks so it is easy to position them in the best place.
Share this post
BTW do they float? or do you keep them at water level by adjusting the lines?
Share this post
We replaced ours last year with two from Aldi at £9 each. Normal inflatable jobs which we used many times on the Shroppie last year, no problems.
Share this post
Yes they float (at least, the pneumatic ones do - can't say about ones with solid tyres).  The distance from the handrail to the water is always going to be (nearly) the same, so the line doesn't need to be altered.  just make it long enough so the tyres sit flat on the  water with a bit of slack.
Share this post
I have two, they float fine.  That Is the puncture proof ones.  I presume the are just filled with closed cell foam, which must be 95% air.
Edited by john6767
Share this post
