Temp sender
Carl123
43 minutes ago, Carl123 said:
Hi I'll have a look at the wires and see what colors. They are the boat was built 1980 ish
At that sort of age and on a UK engine like the BMC, there is a strong possibility the wiring is to British automotive colour norms. A temperature warning sender to light wire would be black with a purple stripe for example. A temperature sender to gauge wire would be green with a blue stripe for a gauge with built in voltage compensation. See here and here.
Jen
16 minutes ago, ditchcrawler said:
VDO is the make, the alarm wont be on the gauge but a lamp similar to the low oil pressure  or ignition lights
There are always exceptions. I have seen a marine temperature gauge with the high temperature warning light was built in to the gauge, but most likely a separate warning light. VDO are a big name in the marine instrumentation market and have been around for a good while.
Jen
