Daniel76
Not much hot water from the calorifier...
Hi, i'm new to the forum, fitting out my own boat currently! My horizontal calorifier is fitted and fed by a webasto and the engine take off hoses for heat, twin coil, and  connected to accumulator and expansion tank just after the hot water out pipe from the calorifier.
I only get 2 litres or so of hot water before it becomes cold, checked and bled the coolant side of the circuit, all fine, adjusted the thermostatic mixer valve to make sure it's not all cold mixing in.
Water does come through from the hot tank, just a very small amount, so unlikely to be a blockage as water is flowing from the tank...im at a loss, any ideas??
Share this post
Could you have fitted the calorifier the wrong way up? The cold needs to go in at the bottom, hot out at the top. If you reverse this, any cold coming in will sink to the bottom and then be extracted, bypassing all the hot. Although the pipes may well both exit near the middle, the pipes continue inside and go to top and bottom respectively.
Share this post
And just to clarify, Nick is referring to the domestic cold water in and hot water out pipes. It shouldn't matter too much if you have plumbed the webasto or engine pipes the wrong way round (and there has peviously been some debate on the forum which is the right way round for these anyway).
Share this post
Almost certainly feeding the cold water into the top instead of the bottom, seen it before. The hot water in the pipe disappears as soon as the cold comes in.
Share this post
Ah ok..these all make sense...I'm assuming I'd have to actually disconnect pipes and rotate whole calorifier in order to get the pipework running correctly I its interior, or is it just a matter of switching the feeds?
Share this post
Best to post a photo or answers might be misleading.
Share this post
I think it depends on the exact details of internal calorifier construction, but best to have a look at the installation instructions for it. It might just be a matter of swapping the pipes around, and at the least that will help a lot, but I think some calorifier are optimised for one way up (not sure).
Share this post
I don’t know for sure either but I can’t think that it could be any other. The coils need to be at the bottom of the tank in order to heat all of the water, surely?
Share this post
Some cauliflowers are built to be used 'lying down' (horizontal) and some 'standing up' (vertical) have you installed the one you have in the correct orientation ?
Share this post
Good point. A vertical cauliflower laid on its side isn’t going to be very efficient.
Share this post
Yep its definitely a horizontal.
Share this post
Is the calorifier one of the Surecal ones that has an adjuster to set the hot water temperature? If so,does altering the adjuster make any difference?
Share this post
See post 1!
Share this post
I think it's seated the correct way up - it's got a sort of flat bottom on the insulation foam from its previous fitting on another boat..I'm trying the cold and hot pipes switched over as I've got no manual or diagrams that came with it (Second hand, not a surecal) and see if that somehow makes a difference...
Share this post
Any chance the domestic water has been piped through one of the coils? A 1" coil full might be about 2 litres.
Share this post
Intersetingly I would expect it to still work piped up backwards. That's how a thermal store works!
Share this post
Just because it was fitted horizontal in another boat does not mean it is a horizontal cylinder.
Pictures will tell us a lot. I've seen many vertical cylinders fitted horizontal and they will work reasonably if the cylinder is fed through the normal outlet at the top, and the flow out is from the normal feed at the bottom, as long as the outlet is at the high point of the installation.
Share this post
But if you only heat a coil full once that water has been drawn off you are relying on heat transfer through the pipe into the flowing water and I suspect it won't be that great. may get luke warm but the OP might be taking that as cold.I bet a thermal store has something more that a plain pipe to transfer the heat into the hoy water - possibly finned, plates or a very long "coil".
Share this post
Yes, but doesn't the 'coil' in a thermal store consist of a multi cored coil so that the surface area is greatly enhanced?
Share this post
Sorry yes I should post pictures, just need to search how to do so. I think it's horizontal as it has attachments for 2 different coils at different ends I.e it couldn't 'stand ' .
I flushed each coil when I got it, to work out each 'set ' so I'm pretty sure I've got them right, also, I'd have 55l of coolant in there and the system for the heating is primed up with around 56l and working great.
Share this post
Assuming you have a smartphone or tablet, to embed a photo you:
  • Take the photo(s)
  • Create or answer a post
  • Press the paperclip symbol, marked "Click to choose files"
  • Navigate to where the photos are stored, (Gallery on an Android device)
  • Select the photos you want to embed.
  • Submit the post
Edited by cuthound
Spillung
Share this post
Hi All, thanks so much for all the replies - I had made a massive balls-up and connected the coolant into the main water part of the tank...(luckily just a few litres).After MUCH flushing out and refilling I've got piping hot water! Thanks for all your help!
Share this post
Looks like Tony B was bang on the money again...
Share this post
