Sign in to follow this
Pirateringo
Can you change engine mounts with a jack?
Hi all, I am going to be changing the engine mounts on my boat soon. Is it possible to somehow jack up the engine enough to change one mount at a time? I'd rather do it myself than pay somebody, and I have someone coming to help realign
Cheers
Share this post
Cheers
The easier way is to have a hoist set above the engine and lift it that way.
Share this post
There's a longish topic on this subject less than a week ago....
It helps if folks attempt a search before asking......
Share this post
Fair enuff, I'll look
Ta
Share this post
If you haven't got a hoist you can place a jack on a strong piece of timber across the engine hole. A trolley jack works well but you could even use a bottle jack. So answering the op's question, yes you can use a jack.
Edited by Flyboy
Share this post
Their name doesn't need to be Jack.
Capitals are important :
You could always help your Uncle Jack off his horse.
You could always help your Uncle jack off his horse.
Share this post
Obviously it depends on many factors. Access, type of stern, etc, etc. Having recently changed the mounts on my BMC 1.8 in a semi trad NB I can't imagine using a jack. Even if access had been possible the risk to fingers, toes to say nothing about the engine would have made it a non starter. I used a chain hoist suspended from a 40mm x40mm steel tube across the cockpit. Anything else would have been plain stupid. Hiring a chain hoist is not expensive. On e bay there's a company in the West Midlands who want £20 a week to hire a 1ton hoist (overkill). How much do you value one of your fingers
Share this post
Wots uncle jack's horse got to do with lifting engines?
Share this post
It wos Jen - Honest !!
She said we didn't need to use anyone called jack.
Share this post
Not stupid at all, I've done it many times using a trolley jack. It's no different to using a chain hoist. You obviously can't lift an engine very much but enough to change the mounts.
Share this post
I'd be intrigued to know how you did it
Share this post
Except for the outboard powered boats, I cannot think of any boat where I could slide a trolley jack under the engine.
Share this post
I never said anything about putting a trolley jack under the engine, you clearly don't understand what I was saying.  The jack goes above the engine on a stout piece of timber across the engine hole, a strop or chain goes over the jack pad and down either side of the jack to the engine lifting points. Simple.
Share this post
Before you start jacking the engine check the mounts to see if they can be dismantled. The mounts on my engine have a threaded rod that can be unscrewed from the flexible base.
You loosen the lower nut on the engine foot then unscrew the threaded rod from the base. Swap the flexible base and screw rod back into the new base. Tighten nuts on engine foot. Repeat for each mount.
The engine remains in position supported by the other three mounts.
Share this post
I went to a panto today. The Fairy Godmother said to Dandini “Your willy’s weak!”  He replied “What???”  She responded “I said, your will is weak!”
Share this post
I had to lift/support the engine if my boat a few years ago and I found a scissor jack worked well, they are small and fit between the bottom of the sump and the base plate.
Share this post
