grockell Posted January 1, 2020 Report Share Posted January 1, 2020 Happy new year all, I have a LED light unit which bulb has blown/broken and is in need of a replacement. Does anyone know where I can source such an item? Pics to follow Cheers, George Link to comment Share on other sites More sharing options...
ditchcrawler Posted January 1, 2020 Report Share Posted January 1, 2020 You will probably need to buy the complete fitting unless you can get it to bits and find someone to fault find and repair Link to comment Share on other sites More sharing options...
Flyboy Posted January 1, 2020 Report Share Posted January 1, 2020 Your LED light does not appear to have any voltage stabilisation circuitry. It will only be suitable for a maximum of 12volts, so even if you find a direct replacement it will fail after a short period. You need one that can handle at least 15 volts for boat use. There are plenty about that have a voltage range of 8 to 30 volts. 1 Link to comment Share on other sites More sharing options...
PaulJ Posted January 1, 2020 Report Share Posted January 1, 2020 Thats quite a bigun. Whats the diameter? Alot of domelights like those used to use a 21w festoon (?) bulb so if you are happy to use a smaller led unit it would be easy to find something eg https://bedazzledledlighting.co.uk/product/g4-wired-21-led/ 1 Link to comment Share on other sites More sharing options...
jonathanA Posted January 1, 2020 Report Share Posted January 1, 2020 Hard to tell from the pics but looks like a modified standard fitting to me so just look for something that looks like it will fit. Link to comment Share on other sites More sharing options...
grockell Posted January 1, 2020 Author Report Share Posted January 1, 2020 27 minutes ago, PaulJ said: Thats quite a bigun. Whats the diameter? Alot of domelights like those used to use a 21w festoon (?) bulb so if you are happy to use a smaller led unit it would be easy to find something eg https://bedazzledledlighting.co.uk/product/g4-wired-21-led/ Around 4 inches in diameter. Thanks a lot for the link, that's really helpful. I'll buy that and give it a go Link to comment Share on other sites More sharing options...
WotEver Posted January 1, 2020 Report Share Posted January 1, 2020 Do none of the LEDs light? It’s unusual for them all to die at the same time. If they have then I’d be looking for a break in the circuit somewhere. This might be of interest to you: https://www.simplelighting.co.uk/6w-circular-led-panel-120mm-diameter-warm-natural-cool-white-led/?gclid=CjwKCAiAo7HwBRBKEiwAvC_Q8dEe5Mkh3y4lOiQxSGM6E41zgWHdTXd3b8wecf1N1lWoaf9k-0a7uRoCoHcQAvD_BwE#fo_c=1144&fo_k=8880e5dd35d9716bb3bc5b46a20a9788&fo_s=gplauk 1 Link to comment Share on other sites More sharing options...
grockell Posted January 1, 2020 Author Report Share Posted January 1, 2020 3 minutes ago, WotEver said: Do none of the LEDs light? It’s unusual for them all to die at the same time. If they have then I’d be looking for a break in the circuit somewhere. This might be of interest to you: https://www.simplelighting.co.uk/6w-circular-led-panel-120mm-diameter-warm-natural-cool-white-led/?gclid=CjwKCAiAo7HwBRBKEiwAvC_Q8dEe5Mkh3y4lOiQxSGM6E41zgWHdTXd3b8wecf1N1lWoaf9k-0a7uRoCoHcQAvD_BwE#fo_c=1144&fo_k=8880e5dd35d9716bb3bc5b46a20a9788&fo_s=gplauk Half of them turn on and the other half flicker on and off or off completely. Thanks for the link, I'll check this out Link to comment Share on other sites More sharing options...
WotEver Posted January 1, 2020 Report Share Posted January 1, 2020 3 minutes ago, grockell said: Half of them turn on and the other half flicker on and off or off completely. Ahh, okay. Yep that’s typical of a dying LED. Link to comment Share on other sites More sharing options...
ditchcrawler Posted January 1, 2020 Report Share Posted January 1, 2020 17 minutes ago, WotEver said: Ahh, okay. Yep that’s typical of a dying LED. often caused by over voltage Link to comment Share on other sites More sharing options...
jonathanA Posted January 1, 2020 Report Share Posted January 1, 2020 42 minutes ago, WotEver said: Do none of the LEDs light? It’s unusual for them all to die at the same time. If they have then I’d be looking for a break in the circuit somewhere. This might be of interest to you: https://www.simplelighting.co.uk/6w-circular-led-panel-120mm-diameter-warm-natural-cool-white-led/?gclid=CjwKCAiAo7HwBRBKEiwAvC_Q8dEe5Mkh3y4lOiQxSGM6E41zgWHdTXd3b8wecf1N1lWoaf9k-0a7uRoCoHcQAvD_BwE#fo_c=1144&fo_k=8880e5dd35d9716bb3bc5b46a20a9788&fo_s=gplauk Not so good for a 12v system given they are mains units.... 18 minutes ago, ditchcrawler said: often caused by over voltage More typical of cheap Chinese units I’d say .... Link to comment Share on other sites More sharing options...
Richard T Posted January 1, 2020 Report Share Posted January 1, 2020 Aten Lighting at Melton Mowbray are another source of LED lights suitable for boat use, Link to comment Share on other sites More sharing options...
ditchcrawler Posted January 1, 2020 Report Share Posted January 1, 2020 9 minutes ago, jonathanA said: Not so good for a 12v system given they are mains units.... This is the problem, they expect 12 volts, not anything up to 14.5 volts with a few spikes along the way. Link to comment Share on other sites More sharing options...
WotEver Posted January 1, 2020 Report Share Posted January 1, 2020 17 minutes ago, jonathanA said: Not so good for a 12v system given they are mains units... I was thinking more for a source of an LED panel after ripping it apart. Link to comment Share on other sites More sharing options...
jonathanA Posted January 1, 2020 Report Share Posted January 1, 2020 If you say so ? Link to comment Share on other sites More sharing options...
CompairHolman Posted January 1, 2020 Report Share Posted January 1, 2020 We have cheap 12v Screwfix led bulbs with no kind it voltage regulation at all and they last years. Link to comment Share on other sites More sharing options...
Ianws Posted January 1, 2020 Report Share Posted January 1, 2020 As above, I’ve had great led lights from bedazzled. The lumens per watt seem to have got a lot more efficient over the years and their bulbs are usually good for variable voltages, I think usually between around 10-30v, so can cope with fluctuations in your voltage. I’ve replaced older led lights with newer ones and got brighter lights for the same amps. 1 Link to comment Share on other sites More sharing options...
WotEver Posted January 1, 2020 Report Share Posted January 1, 2020 1 hour ago, jonathanA said: If you say so ? Yup, much the same as post #4. I couldn’t find the panel currently used in OP’s lamps and the 2” unit from post 4 might look a bit weedy, so I searched for a 4” one. Link to comment Share on other sites More sharing options...
Ianws Posted January 2, 2020 Report Share Posted January 2, 2020 I replaced some very gloomy leds, just the plug in bulb units not the fittings. Went for something slightly more powerful and they were too bright for me. I think efficiency has improved. Look at lumen output rather than wattage. Also cool or warm makes a massive difference. Would be good to try one first but then you would be stung with extra postage. I ended up buying a replacement set for the original replacements. Not a massive amount but I was only replacing 3 bulbs. Link to comment Share on other sites More sharing options...
robtheplod Posted January 3, 2020 Report Share Posted January 3, 2020 I'm replacing all of our LED lights from cool white to warm white - the difference is amazing.... cool white is a very harsh light... Link to comment Share on other sites More sharing options...
