Sign in to follow this
tortuga guy
Resealing Caldwell's windows
Hello all you wonderful people, I wondered if any of you knew of a good window fitter in the London/Uxbridge area , I have 3 windows that need re sealing , willing to pay obviously, and plenty of tea and biscuits of course , any reply will be greatly appreciated, thank you all for your time.
Share this post
Strange that you have had no response. I can’t personally help. But may I ask is it to seal the glass in the frames or the frames to the boat side?
We have Caldwell Windows. We had a couple of tiny seepage issues a few years ago. Rather than take out the frames I tried to loosen the retaining screws near to where we thought the penetration was, (some screws didn’t budge) anyway applied a very small sliver of sealant along the edge of the frame and carefully wiped off with a damp cloth. What couldn’t be wiped off sealed the gap. Tighten the few screws that did move. I was surprised that it worked. Saved a load of hassle.
Share this post
That sounds like a neat trick and may try it, it may help till a proper fix, thank you
Oh its the frame BTW, thanks again.
Share this post
Or try Captain Tolley’s creeping crack cure.
it stopped a leak I had until I could fix it properly.
Share this post
THANK you I think I have some of that somewhere, cheers.
Share this post
I second that, really good stuff.
Share this post
Have they changed the formulation of Captain Tolley? The liquid in my previous tube was extremely white (like milk) and worked perfectly; last year it ran out and I bought some more. Not only was it a relatively clear liquid (still white but almost see-through) but also even when it had dried it was water-soluble and got washed away by the first rainstorm so it was totally useless.
Share this post
Mnnn.    Sorry but don't know the answer to that. Mine was bought about a year ago and is milky
Share this post
Worked for me. Even sealed two leaks that had been present for years before I bought the boat (oak inner frame completely rotted out in two corners) - mine had an inset rubber bead to cover the screws and removing a bit at the top before applying liberally sealed whatever the source of ingress was.
Edited by wiltshirewonderer
Share this post
Yup, and a covering of wateproof tape over the joint will keep the worst of the weather off it to give you a fighting chance of the seal seeing you through to the better weather. You can replace the tape as needed, but I have had a bit on my similar issue for a month so far.
Share this post
