Water rules
dor
The water authorities have been getting twitchy about all these hosepipes being used on the canals and the potential risk of contamination of the water supply.  It is now normal to have check valves in taps used to fill water tanks, but the water authorities are proposing more restrictions.
Among their suggestions are that hosepipes must not be laid on the ground or allowed to come into contact with canal water (risk of contaminants penetrating the plastic), hoses should be completely empties after filling, and the hose reel stored inside a plastic bag. Plenty of other restrictions, particularly for marina and CRT supplies, e.g. requiring a ball cock arrangement between supply and tap.  All to reduce to near zero the possibility of anything in your hose pipe entering the supply system (which could occur if there was a failure in the supply which reduced the supply pressure at the tap to zero).
Best-Practice-Marine-Water-Facilities
Some of the content:
The agreed IBP for boat owners states;
When boats are ready to fill up their on-board cold water storage tanks from a designated drinking water filling point, or mains water standpipe via a hose pipe, the end user must follow this simple Standard Operating Procedure (SOP)
1. Ensure that you only use your dedicated wholesome water hose pipe when connecting to the water delivery device.
2. Moor the boat so that you have adequate access to the drinking water delivery system.
3. Ensure the hose is safely secured to the drinking water filling point on board the boat.
4. Do not allow the hose run to be in direct contact with any canal, river, lake, or other water courses, as allowing it to be submerged can lead to permeation of the hose. Permeation causes contamination of the mains water drinking supply which passes through the hose to fill the on-board cold-water storage tank(s). This poses a serious risk to public health and to those persons consuming the water downstream of the standpipe.
5. Do not allow the hose to lie in puddles.
6. Do not allow the hose to lie on the ground as this can also contain contaminates and encourage ingress.
7. Once the filling process has been completed, turn off the hose union tap, then physically disconnect and remove the hose. Once the hose has been disconnected, completely empty the hose of any excess water and stow the hose away in a re-sealable bag to prevent ingress and contamination from outside sources.
8. At no time shall a hose be left as a permanent connection due to its permeable nature. Such action can lead to a potential contamination risk and may result in legal action and/or possible criminal prosecution.
When washing off boats with a hose pipe also have a trigger gun on the end of the hose to ensure that the hose turns off the flow when released.
Edited by dor
I have been 'banging on about this for years but just accused of scaremongering.
I have this document but as it is a Pdf I cannot post it due to this forum software restricting Pdfs.
Examples of a couple of pages :
So what's the difference between hoses used by boaters and hoses used by farmers or people with gardens who may have animals defacating outside? Also, are there any documented cases of contamination of the mains water supply from a boater's hose?
I'm always pretty cautious about using shared hoses for filling my water tank because you never know what some other boaters have been doing with them - rinsing out a pump out, etc.
Edited by blackrose
6 minutes ago, AWETHEAYET said:
I would have thought that if all supply systems were fitted with non-return valves, then what goes in the boat is up to us. If someone chooses to trail their pipe through the mud, and often this can not be avoided, then this is their choice.
Yes, if the risk is so great then why don't they just fit all vulnerable supply outlets with NRVs. You can't regulate the behaviour of everyone.
5 minutes ago, ditchcrawler said:
I thought they did, double check valves at that.
The law says that they must be fitted :
Under health and safety legislation, marina operators
must ensure that employees and visitors to their
premises are not put at risk, and berth holders and
boat users visiting marinas also have a responsibility
to ensure they do not create health and safety risks.
This legal duty is reinforced by the Water Industry
Acts and the Water Fittings Regulations (or equivalent
legislation in Scotland and Northern Ireland), which
require marina operators and users to ensure that
water supplies within the premises are adequately
safeguarded against contamination. Operators and
users also have responsibility for ensuring that water
fittings are installed and maintained in compliance with
the regulations. The Water Supplier has the power to
prosecute those who infringe the regulations, and can
disconnect supplies that pose a serious risk to health.
A water supplier may take action to recover from
marina operators the costs incurred in responding to a
water contamination incident, which can be significant.
5. Backflow Prevention
The seriousness of the risk of contamination by
backflow is assessed using one of five fluid categories.
Examples of these include:
Fluid category 5: contaminants, which are a
serious health risk. Fluid containing pathogenic
organisms, radioactive or very toxic substances.
Fluid category 4: contaminants with a significant
health hazard. Fluid containing toxic substances
including chemicals, carcinogenic substances,
pesticides and environmental organisms of
potential health significance.
Fluid category 1: wholesome drinking water,
as supplied by the Water Supplier.
The degree of backflow risk is dependent on local
circumstances. Risk assessments, if not carried out by
your local water supplier, should be confirmed by it.
The regulations require that plumbing systems, fittings
and appliances are protected by suitable backflow
prevention devices rated to provide protection to at
least the same fluid category as indicated by the risk
assessment.
The Water Regulations Guide provides
information on the fluid category rating of different
types of backflow device.
WRAS
Edited by Alan de Enfield
So where do you think they are going with this one?
We pay extra to fill up if we can not follow the unatainable guide lines?
Surely through licience people are paying for water and should not be expected to pay extra. or am I missing something
4 minutes ago, WotEver said:
If you’re being thick then I’m every bit as thick myself.
Do you know why NRV valves are fitted?
I'm not suggesting by this question you are thick.
I may be more thick than you think you are in suggesting the following
"pressure of water is maintained by the capacity of the pumps providing it" "if pumps are used to take water from the supply outstrip the supply then they will suck water back up the system"
Hence the need for non return valves.
I'm sure in reality its some what more complicated than this.
6 minutes ago, Cheshire cat said:
Presumably it was this kind of sabre rattling that started C&RT changing all the waterpoints to those stainless ones and withdrawing the hoses from Elsan points
As the OP said it is "best practice"
CRT have legal responsibliy and are fully aware and conforming (in the main) to the current laws.
We has end users, and payers for water, should expect safe supply and not polute others users.
Yes, so that the system can’t be back-fed, potentially polluting the supply. Every outside tap you buy from B&Q has had one for years. Then the tap connectors from the likes of Hoselock also have an NRV.
Nothing new at all, its all been a requirement for a long time. Double check valves. Supply break tanks would lead to very low pressures and long filling times,,,,,, giving more time for permeation and contamination. And storage tanks need periodic sterilization to combat Legionella.
I see that there is no mention of food quality approved hoses being used rather than garden hosepipes.
This is "best practice" not "rules".
I'm sure most water point taps are already fitted with double check valves, and most boaters already follow reasonable practices to keep their hoses clean etc. Those who don't are only endangering their own health and there is virtually no risk of contaminating the public water supply.
And how are you supposed to run your hose from the tap to the boat without it lying on the ground?
It is legal requirement ("The Law")
The Water Supply (Water Fittings) Regulations and Water Supply (Water Fittings) (Scotland) Byelaws, play an important role in protecting public health, safeguarding water supplies and promoting the efficient use of water within customers’ premises across the UK.
They set legal requirements for the design, installation, operation and maintenance of plumbing systems, water fittings and water-using appliances. They have a specific purpose to prevent misuse, waste, undue consumption or erroneous measurement of water and, most importantly, to prevent contamination of drinking water.
Not according to the OP.
I'll be impressed if you can quote a water regulation preventing a hose pipe being used if it is touching the ground, for example.
It's just advice, nothing more.
