Ray T
Lister LPWS3 fuel feed pipe.
The flexible fuel feed pipe to my engine has become porous and is leaking fuel into the bilge and obviously needs replacing.
To my knowledge it has been there at least 10 years, possibly 21 years, the age of the boat
The fuel pump end connection looks fairly straightforward to undo, photo 1.
The fixed line from the tank connects to the flexible line by some sort of union, supported by a clip, photo 2.
To undo it do I put a wrench around the knurled looking section, top of photo and obviously a spanner on the lower end?
Of course I will shut the fuel feed pipe off before I do anything.
Thank you.
Photo 1.
Photo 2.
Edited by Ray T
Share this post
What you call the "knurled looking section" is whrer the flexible hose is crimped onto the solid fitting at each end.
In photo 1 you need to put the spanner where arrowed below, pulling the top of the spanner in a downward direction in the photo, to unscrew the brass nut:
In photo 2 you do similarly, but probably need to remove that clamp first and put a second spanner on the fitting under the clamp, before unscrewing the visible nut..
Edited by David Mack
Share this post
When you have a new hose made up they can re-use the fittings and crimp them onto the new pipe. Sam at Foxton Boat Services did one for me. Note that the new hose must have the relevant BS markings on it to pass the BSS
Share this post
I've had them done by Calcutt using the existing fittings as WotEver said.
Share this post
20 minutes ago, Ray T said:
Off to the local branch of PIRTEK in the morning.
https://www.pirtek.co.uk/
Always found them good, if not the cheapest.
Nuneaton Hose & Fittings are great too. But I guess that’s only useful to someone in Nuneaton ;)
Share this post
Thank you, I live in Coventry.
Share this post
