Over plating added rust protection advice please
Missmoo
We are in the process of over plating our swim and a length of the side. We would obviously like to ensure that any further rust damage is limited. We were thinking of using cold galvanized paint on the seams and other areas. Can we black on top of that please. Soon after. Or does anyone recommend a high zinc primer which can be blacked over ASAP. I know it’s a crap time of year to be over plating. Thank you.
Edited by Missmoo
Irrelevant bits
I've painted jotamastic 87 epoxy (now superseded by jotamastic 90) with a winter grade hardener in these conditions successfully. But you'd have to get any existing bitumen or other paint off first back to bare steel.
The Jotun TDS shows application possible down to -5C
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.jotun.com/Datasheets/Download%3Furl%3D%2FTDS%2FTDS__16560__Jotamastic%2B90__Euk__GB.pdf&ved=2ahUKEwjQxK6u3ZPmAhWRiFwKHa9VAYwQFjAAegQIBxAC&usg=AOvVaw2aiFRukqg7INfdXUphJJi0
Edited by blackrose
