Stern Gland Packing
Old Son
I'm blacking my boat next year and thought it a good idea to replace the stern gland packing. How do I measure the size of packing I need whilst the boat is in the water? The only way I can see is remove the two nuts, withdraw the slider and measure with a Vernier gauge. Is there any other way please?
1) I believe there are only two-sizes, by a length of each.
2) Find someone with the same gland / shaft size and ask them
3) Wait till you get it out of the water - It'll be out for at least 7 days so you can measure it, nip to the chandlers (or buy on line with next day delivery) and pop it back in.
11 hours ago, Ray T said:
Get a set of metric and imperial drill bits and see which one fits in the gap.
But I would then need to remove the slider? If I have to I will but I was asking if there was another way without removing the slider.
Yes, as describe by Mike in post 3 as long as you have a pair of calipers. That is unless the packing is so far gone the flange on the slider is hard against the stern gland housing. Without a photo there is always the possibility the OPs gland may not have a visible slider or the packing is in a great big nut affair.
If you decide to remove the slider it's very easy, guick and safe to do.
Wind down on the greaser to make sure there's grease in the gland & stern tube
Remove the 4 nuts on studs
Slide the slider out to give access and clearance. You may ffind that some form wooden levers help.
Measure using chosen method,
Replace slider and nuts
Adjust as appropriate
On 09/11/2019 at 12:34, The Welsh Cruiser said:
If you do remove the slider I hope you don't find it a bit tight, then even tighter when you try to put it back on, due to a slightly misaligned engine :)
Let's hope this wont be the case!!
On 09/11/2019 at 11:34, Mike Adams said:
Try to get some ptfe based packing if you can. I have found it works much better if you have worn bearings
I'll be changing my packing next year when it's blacked as well and when I asked about the sizes I was advised of using PTFE based. Originally accepted the advice but when I thought about it further it occurred to me what happens should the PTFE wear off? I mean it is essentially the coating on non-stick saucepans, and a lot of the coating on some of our pans has worn off. The alternative is graphite based and whereas PTFE is a coating, graphite is a lubricant so I'm now a bit torn between the two, tending to come down on the side of graphite.
The other point would be that if you have worn bearings, it may be a good idea to address that problem.
PTFE is a plastic, and thus can be moulded into many shapes, not just sprayed onnpans to give a non-stick finish.
It has a coefficient of friction similar to wet ice and thus is often used for bearings and gland packing.
https://www.fluorotec.com/materials/ptfe/what-is-ptfe/
My ptfe packing has done 19 years so far  https://www.asap-supplies.com/propeller-drivetrain/gland-packing-and-removal-tools/prop-shaft-gland-packing/drive-force-ptfe-flax-sturntite-gland-packing-807521
Edited by ditchcrawler
10 hours ago, ditchcrawler said:
I'll measure mine at the weekend. 5mm sounds a little small if the sizes suggested in this topic are correct. Presumably the packing needs to fit reasonably tight?
18 hours ago, Slim said:
It's like a dream to me that some years ago I read that graphite impregnated gland packing was not a good idea. Only a dream, no facts
It means that any grease which escapes from the gland  makes indelible black stains on anything it touches. Don't ask me how I know this.
MP.
MP.
Where is graphite on the galvanic scale compared with mild steel, stainless steel, brass and aluminium? I suspect that may explain why graphite packing might not be ideal but can't see it mattering so much in fresh water.
Way up there, hence never use graphite grease on a boat, anywhere.
