As per the title, my engine has a simple steel plate which has at some point been made and fitted to replace the original cast item. Inlet/exhaust manifold side of the engine.
It would be nice to return it to original if anyone happens to have one knocking around?
On 31/10/2019 at 15:02, David Mack said:
I saw the headline and was going to suggest that if the cast original was damaged or missing, it should not be too difficult to make a replacement from steel plate!
Yes, to be honest it doesn't look out of place - it's only when you look closely that you realise it's not an original part!
