Sign in to follow this
haggis
Flooding
14 hours ago, Alway Swilby said:
Two days ago (Thursday) I was chatting to an EA chap who was having a look around at Isis Lock. The pound above the lock was quite high (as shown in the Oxford correspondant's first photo) and the weirs were flowing strongly. EA chap said the most of the extra water in the canal pound had come from drainage from the Oxford area. I should have asked him about Dukes Cut and whether that was feeding into the canal but I didn't. Later that day I noticed that the paddles were up at both ends of Isis Lock, presumably on purpose. At about midnight that evening the pound was about four inches below it's normal everyday level. Seeing as how I was moored on that pound and I didn't fancy coming to rest on the bottom I went down to the lock and closed the top paddle. The weirs wern't flowing at all. The pound recovered overnight to its normal level and the weirs were flowing as normal. Today (Saturday) the paddles are both up again but this time the pound is retaining it's level. The drop at Isis lock is just about six inches or so at the moment.
I wouldn't have thought they need to open the paddles at Isis lock to manage water as there are big overflow weirs on that pound? Also I think those photos are Osney lock on the river?
Share this post
As it says, one photo is of the pontoon below Isis lock on the canal; and one of the lock moorings below Osney lock.  CRT signs in the former,  and EA bollards in the latter.
Edited by Scholar Gypsy
Share this post
15 hours ago, Alan de Enfield said:
That's high !
It's recently been a little higher than in the picture.
In  past years significantly higher still.
Its  the long term duration of the flooding that seems unusual this time .
Share this post
Kings marina is about 6' above 'normal' with the walkway-ramp almost horizontal.
Share this post
Probably 5ft at Farndon.
The water level did reach the top of the slipway and started to flood the yard. Its left behind a rather large puddle.
Water levels slowly falling now.
Share this post
We have just had a trip to the Lincolnshire coast with Syd for his birthday. We can't remember a time we have seen the ground quite so sodden and all of the ditches and watercourses so full.
There is still plenty of water to head into the rivers.
The Trent was on the verge of shutting Dunham Bridge creeping across the field and to the low point where it floods the road. The Fossdyke was also high.
It needs to stop raining!
Share this post
I was at a classic car meet at  Montford Bridge, just upstream of Shrewsbury, this morning and the Severn is still well above normal levels. Locals are saying it is going down much slower than normal.
Share this post
Same in the Trent.
The fields around here have standing water on them and the ground will be at 100% of its capacity to hold water. This will take a while to drain back into the river and can only start to do so as the river level starts to fall.
Share this post
Stopped at Gunthorpe briefly after a soggy wet day segwaying and go apeing in Sherwood Forest. Never seen the Trent flowing at this speed....
  • Horror 1
Share this post
Flooding like that was an annual Winter event at Gunthorpe (we used to live a coupe of miles down the road) but improved flood control means that over the last 20+ years it has become a less frequent event.
Share this post
You might not have seen it but the water level has been higher than it is today.  So it must have flowed at that speed on previous occasions.
However I do agree the present speed and energy of the river is formidable.
Share this post
Ah yes my mistake...was looking at them in the wrong order! Still surprised they would have needed to open the paddles on Isis lock rather than rely on the weirs?
Share this post
The weirs were going full pelt and still the canal was overflowing the top gate of Isis lock.
Share this post
As I understand it, speed and level are not exactly correlated
Share this post
On the non tidal river they are related.
Otherwise at a given water level what do you think makes the river flow faster or slower?
Share this post
I am not an expert:
Firstly, quite a bit of the discussion has been about tidal, or semi tidal, rivers. As I have found out the hard way, level and speed on tidal waters are very complex and even long serving lock keepers can get their advice wrong at times.
Secondly, two significant factors: what profile the channel has at any given point. For example, if a river section has a flood plain area outside the normal channel but with a flood bank further away, then I suspect the rate will drop quite dramatically once the level reaches that point. It will certainly vary across the width of the river. Also, a lot will depend on what is happening up and down stream. Is the water backing up against higher levels further down?
What I have learnt in recent times is to have a lot of respect for water management professionals who are developing quite sophisticated models that help to predict what will happen in the short term and what also is the best (often a compromise) action to alleviate damage with the tools currently available. What is clear is that many amateur views, perhaps based on rather dated techniques, lead to loudly stated criticisms that have limited real substance.
Share this post
6 minutes ago, Mike Todd said:
...  two significant factors: what profile the channel has at any given point. For example, if a river section has a flood plain area outside the normal channel but with a flood bank further away, then I suspect the rate will drop quite dramatically once the level reaches that point. It will certainly vary across the width of the river. Also, a lot will depend on what is happening up and down stream. Is the water backing up against higher levels further down?
You are quite correct the speed of flow is affected by the shape of the channel and is in general greater in the middle than at the edges  That's because of friction between the water and the river bed and the bank sides .
What has been implied is the speed at the given depth it was at in the video clip was faster than it might have been on another day . Given the same water level at any particular place the same speed profile across the channel  will  always  be observed (in a non tidal section river and given no other man made influences ) .
I hope that's clear but its not easy to explain in a few words .
Share this post
These photos are of Torksey Lock today
74278429_10216189619518282_2188182848291
73124640_10216189619798289_5051402678542
74647609_10216189620078296_2853449441078
78173747_10216189620918317_8970046649464
74412218_10216189620518307_5407321631905
Courtesy of Suart Kinch on the Torksey group on Facebook.
The area is on amber alert for flooding and it has been said it was worse in 2000 and in 2007. (but it receded faster in those years)
It would seem that somebody decided this was a good time of year to replace the pumps at the " Trent Valley Internal drainage board at Torksey" ... obviously they were unlikely to be required in November.... sigh
Share this post
It took me a while to work out what was canal, what was river and what were fields. It will have to come down a long way before I get a chance to cruise past in a few weeks time.
Share this post
Seen on Facebook that the Thames is over the bank in Abingdon and the Cherwell flowing into the canal at Shipton!?
Share this post
Impressive pictures.
Is that a ship on the pontoon?
30th November ?
Share this post
30th November ?
It is a crane barge. Looks to be of dutch origins with the beautiful shape of the stern which I have managed to not get a picture of.
It has been there for a long while now.
Share this post
Now you mention it there were some temporary signs on the pontoon when we were there in mid September.  But no barge present at that time.
Edited by MartynG
Share this post
