A complete Idiot
luggsy
8 hours ago, blackrose said:
But it does happen if the volume of water in either vessel is higher than the other.
That’s essentially the same thing that you suggested in the first place.
Think of an empty lock chamber and a long pound full of water above it. Open the top paddles and you have a real life example of the theoretical model that  Stegra describes. The flow ceases when the surface levels are the same but the volume of water will still be very much greater in the pound above than in the lock chamber.
Conversely, rivers don’t flow from the ocean to mountain lakes.
JP
13 hours ago, David Mack said:
A single set of gates at a flash lock would still be lock gates. I'm not sure that flood gates are sufficiently different for 25(a) not to apply.
But is it a flash lock? Or are they "flood gates"?
A flash lock would have a reliable method of opening it against a significant level difference.
Or does the difference lie only in the intended use?
And that is exactly the point: it is the difference in water height that creates the pressure which, if unrestrained will lead to the water 'finding its own level' but when restrained exterts a force on the restraint. Of course, moving water is a very different matter.
Yes. And the volume of water makes no difference, only the levels. When you open the top gates on a lock, the additional volume of water from the pound doesn't increase the pressure on the closed gates.
Likewise, if you dive down 3 metres in a (saltwater) swimming pool the pressure is the same as if you dive down 3 metres in the middle of the Atlantic.
13 hours ago, Mike the Boilerman said:
After failing to open the gates, did this chap moor up and wait? Or turn around and cruise back from whence he came?
Idiot or not,  I hope he got somewhere safe with the way the rivers are rising round there, and more rain coming.
Edited by matty40s
  • 2 months later...
