NewCanalBoy
Testing an Eberspascher (sp?) ?
Yes, God knows how to spell it.
Can you test to see if Eberthingy heater until works if it currently does not have s fuel feed ?
Can you give it a 12v feed to see if the fan unit works on it or does it require a fuel pressure before.
Just trying to work out if a unit I have is working or not.
There is a multi plug electrical socket but don't know if I can test something through there.
Share this post
Applying voltage to the motor will turn it, but that will prove nothing. Check your motor first as to the required supply, as iirc, they may run on areduced voltage from the controller, A Mikuni I looked at only ran 9 volts.
Share this post
19 minutes ago, TheBiscuits said:
Feed it from a can of diesel.
I thought it needed a pump to put pressure to it ?
Does it just draw diesel through then ?
Share this post
It needs the metering pump connected, yes, but that will happily sip from a can of fuel.  That and a fully charged battery are all you need to run it up and test it.
Share this post
The place I had ours serviced at, the boatyard at Gailey top lock, have a test rig set up outside to run the heaters on. It supplies a fuel source, electrical source and a coolant source since my limited understanding of the things is that without these three, the management unit detects a fault and will not let the thing start.
Share this post
Is the metering pump a separate thing or is it built into the unit ?
Share this post
Separate.
Share this post
1 hour ago, MartynG said:
Separate.
Ok, in that case I haven't got one !!
Might need to unbolt it and take it to someone.
I remember now asking about how fuel efficient they are and it didn't seem like they were very.......off to start another thread.......
Share this post
You must have one!
Its the fuel pump that goes "click click click" while it is failing to start.
You must have one because you are seeing fuel mist from the exhaust.
Share this post
Separate.
I think my D5W has it built into the casing. A previous model fitted to my boat had it as a separate unit.
Share this post
12 minutes ago, NewCanalBoy said:
Oh I see, you mean the main fuel pump for the engine ?
No, it looks like this and goes in the fuel line to the unit:
But I see there are now two threads running on air heaters that won't start. Maybe I'm confusing the two threads.
Share this post
 V1 Doodlebug.  Pulse jet, like a big paraffin blow lamp.
Share this post
I recently bought an old D5W that was from a BT van. I hacked the wiring and fitted a couple of fuses ..one for the switch and one for the heater.
Stuck the water inlet and outlet hoses into a bucket and a short length of fuel hose into a jam jar of diesel.
It fires up just fine.. doesn't need any pressure on the fuel line.
Once the switch is activated..it goes into the correct start up...water pump..air fan...and finally the tick tick fuel pump. Conversely..it does the correct shut down.
I'll fit that in the coming months.
Share this post
16 hours ago, NewCanalBoy said:
Ok yes, that wasn't me. Haven't got one of those, thought I was missing something.
Without one it won't start. ...
Share this post
Fuel and electric, and they fire up.  They will go into overheat shutdown shortly afterwards, but they run enough to prove that they work ...
Share this post
