W+T
Can we ID this stove ?
I have this stove on my  o9at and was wondering if anyone lnows what make etc it is pleaae.
Admiral Faffer:)
Share this post
6 minutes ago, Ray T said:
It's not a Willow but looks a bit like a Vallor Willow. A smaller version perhaps?
See the source image
Well its very similar and i reckon steel construction. Only want to know if it a good one and not some cheap thing.
Share this post
Admiral Faffer:)
I think you need to ask @rusty69 ...
Share this post
33 minutes ago, Cheshire cat said:
It looks like Wayne is in the market for a sandblasting kit
At least its not cast and about to fall to bits
Share this post
I knew i shouldnt of sold my kit begining of summer. always the way hey. I have a stove in the workshop that needs a good refurb aswell.
Ah well, wire brush will be coming out. Nice job to do on the mooring with we few ciders :):)
Share this post
Eighteen squids Wayne:
https://www.machinemart.co.uk/p/sb4-sandblast-kit-pick-up-hose/
Share this post
43 minutes ago, WotEver said:
Could be worth a look. I only have one compressor now but it mite do the trick forgot the CFM. I ran the last blast pot with both but borrowed the motoor off one for the table saw.
Share this post
9 hours ago, CompairHolman said:
Must have belonged to Stevie Wonder going by the weld on the collar of the flue.
Not looked closely but the flue slides inside the collar and rope or cement is used. Either way i have a nice new one at hand :)
Edited by W+T
Share this post
What weld?
Share this post
3 hours ago, J R ALSOP said:
They look like tide marks up the door glass. Good stove though.
Well spotted, the boat was sank for a time and resting that side at an angle.
Share this post
13 hours ago, WotEver said:
Arada is the manufacturer. Hardy 4 is the model. As per post #4.
http://swww.aradastoves.com/hamlet/stoves/hardy-4
They must have changed the model slightly then. Our stove has sharper edges and no lever on the left. I assume this helps clear the grate.
Edited by MHS
Share this post
My AX2 model size seems to match the Hardy 5. I assume they changed model name to sound less like a Citroen car!!
Edited by MHS
Share this post
I do some work for Machine Mart and I’m aware that they’re constantly updating their fires, sometimes only subtlety, mostly to achieve DEFRA approval. I’d guess that all manufacturers do the same.
Share this post
On 12/09/2019 at 10:42, WotEver said:
What weld?
You're right , looking in close up its some kind of sealant.
Surface rust like this doesn't need sand blasting that would be way over the top, you just need a wire wheel in a grinder . ( never use wire wheels without eye protection )
I have restored plenty of stoves over the years.
Share this post
Got it home and soaked it for a few days in wd40. Took some  loosening  but managed  it.
Grate bars are good which i good great
 Pan is shot though. No biggy.
As you can see the flue wasn't  welded as thought
20190916_175759.jpg.aa1a33ffb9074b53fe45df070418f5de.jpg20190916_180154.jpg.4336c564c016ee2fb6b874007b11e7ba.jpg
So time for a clean up. Fire it up and repaint it. I thought the walls would be thicker. I made a few stoves in the past and used 8mm plate. Hope to get a new tray but easy 20190916_180157.jpg.8a6a634d9b9229296952b3dca79c8bea.jpgto make one if i can't.
Share this post
